09-08-2021, 06:02 PM | #1 |
Drives: 2018 camaro 1SS Join Date: Apr 2020
2012 Camaro V6 overheating
Hello everyone
I am wondering if anyone would have an idea on what is overheating on the car I do hear and see smoke coming from the back of the engine block just don’t really know what goes back there my car is a Camaro V6 I will attempt to upload a video to have a better view in what I’m seeing TYIA |
09-08-2021, 06:04 PM | #2 |
09-09-2021, 11:23 AM | #3 |
Drives: 2011 Camaro 2LT Join Date: Oct 2018
It looks like you have a coolant leak to me. There’s a coolant outlet pipe shown as #16 in this diagram that other members have had leak issues with. I’d start there but also check all upper/lower radiator hose clamps, the overflow hose, etc. Also check your coolant level immediately. Given what’s going on, I’d check the level in the overflow bottle and take the plastic engine cover off, remove the coolant cap by the power steering pump, and see what the coolant level is in the block. Is the car throwing any codes at this time?
09-09-2021, 04:51 PM | #4 |
Drives: 2011 RS/2LT- manual Join Date: Aug 2021
It's my understanding that the gaskets at the water pump can fail. That could explain the steam from the back of the engine, and loss of coolant.
09-10-2021, 12:50 PM | #5 |
376 cubic inches of fun
If your cooling system is not pressurized, the boiling point of the coolant goes down and you will overheat.
Since you can see steam escaping the system, you have that problem. Even if you keep adding coolant, your car will continue to overheat and lose coolant. |
09-22-2021, 02:36 PM | #6 |
Drives: 2011 2SS, 2006 GMC Sierra Join Date: Jul 2019
Thermostat housing is back of engine on passenger side.
Probably leaking |
10-04-2021, 03:08 PM | #7 |
Drives: Chevy Camaro RS and SS Join Date: Sep 2021
Also check your coolant temp sensor. My water pump was leaking and after we changed it the coolant temp sensor went out. Was driving with new coolant full and the temp ran up to hot and said the car was overheating. Disconnected it for a few hours til i got a new one and problem solved.
Thread Tools | |
