Old 12-17-2018, 08:13 AM   #1
Rogue Leader
Iatefiberglassinsulation
Rogue Leader's Avatar
Drives: 2010 Camaro 2SS M6
Car won't pass emissions ECU monitors will not set
Hi all, been a while.
I'll try to keep this as short as possible. My Camaro 2010 2SS 6 Speed (original owner) hasn't been driven much the past 2 years, maybe about 1000 miles, had some cooling system issues and also just time/baby seat won't fit in back. But it has about 72k on it. Anyway up until a couple weeks ago I was still on the original battery. Last year when I went to get it inspected the monitors were not set and my mechanic suspected it was because the car had been sitting and its first start in a while it kinda chugged slow which may have reset the computer. Drove it about 50-60 miles and it worked and passed.
This year same thing happened, but I said ok time for a battery. Keep in mind the only reason I think that old battery wasn't flat is because the car stayed in my garage on a Battery Tender. Clearly while it held voltage, it was weak and the CCAs were low, hence the starting behavior last year and this year. So I swapped in a new battery, now it starts strong.
When i swapped it in I hooked up a scan tool and I've been monitoring to see when its ready to inspect. FUEL, EVAP, and O2S all show as not set. After about 20 miles FUEL set itself. But now I've done over 200 miles, a lot of short trips but multiple longer drives and EVAP and O2S will not set. I in fact only need 1 of the 2 to set for it to pass NY State Emissions.
There are no codes and no SES light. I checked the live data and all 4 O2 sensors are putting out similar readings and functional.
One side note. About 5 years ago at 54k miles I had a collapsed valvespring on the drivers side bank. Dealer pulled the head and replaced everything damaged and put it back together. About 5k miles later I got an SES light for the catalytic converter also drivers side probably due to all the raw fuel that got dumped into it. Dealer replaced that as well under warranty. Keep in mind the car passed NY state emissions 5 times since this has happened. I would think there is a fouled O2 sensor, but like I said the readings at least look normal and I still don't have an SES light after about 200 miles and multiple drive cycles.
Any ideas? Just keep driving it? Getting close to snow time, hell this car hasn't even seen rain in 4 years and now it has twice. Not that I'm scared of it (I used to daily drive it, through snow and so on, this car has been through a lot!) but my life situation these days has allowed me to keep the car "perfect" and enjoy it in fair weather, but it needs to pass inspection!
2010 Chevrolet Camaro SS - was daily driver, now toy
2020 Alfa Romeo Giulia Quadrifoglio - Daily Driver
2017 Mercedes Benz GLE 350 - Wifes Car
2008 Chevy Silverado 2500 HD LT 6.0 - Tow Vehicle
1991 Alfa Romeo 164S - Project Car
1994 Volkswagen Golf - Race Car
"Like" my race team on Facebook: http://www.facebook.com/farfrumwinnin
Rogue Leader is offline   Reply With Quote
Old 12-17-2018, 09:38 AM   #2
craigd853
Drives: 2010 SS Camaro
Get on the internet and look up how to set computer on a GM car after the battery has been disconnected. I did the same thing a couple of years ago and there are very specific directions for setting sensors on a GM car after the battery has been replaced. Car has to be driven at certain speeds and has to be in a specific gear for time frames in order to set all the parameters u r lookinG for, hope this helps.
craigd853 is offline   Reply With Quote
Old 12-17-2018, 10:19 AM   #3
Rogue Leader
Tried that and couldn't find a single thing specifying this procedure at all. Also keep in mind my monitors were off BEFORE replacing the battery, and the original battery never really died at all. Do you have a link?
Old 12-17-2018, 10:55 AM   #4
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
You might still just need to drive more. Most GM cars require a few full cycles of operation and if I recall correctly it's around 300 miles.
Did you ever get a tune for this car?
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 12-17-2018, 10:59 AM   #5
Rogue Leader
Nope never tuned. Unfortunately my commute is super short so I've been taking it on some weekend drives. Today I left the keys with an old friend (who has a collection of GM performance cars so I trust him) and he is taking it on a REALLY long drive after work to see what happens. Probably 100+ miles round trip. Hopefully that does the trick.
Old 12-17-2018, 12:21 PM   #6
tazman
tazman's Avatar
Drives: 2014 ZL1
http://www.obdii.com/drivecycle.html
The O2 should be easy to get ready if everything is good.
2014 ZL1 Roto-Fab intake, 2" TSP headers, JRE 125 package and tune.
2015 2LT RS overkill tune, 80MM throttle body with JacFab spacer, ported intake manifold and Roto-Fab cold air intake. Vitesse throttle controller.
tazman is offline   Reply With Quote
Old 12-17-2018, 12:36 PM   #7
Rogue Leader
Sweet I'll try to give that a whirl tonight
Old 12-17-2018, 03:06 PM   #8
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
When I read this thread, I have a question ....
How do I replace the battery without complicating my life by restoring the system?
Linking another car to the poles in the engine compartment?
Does not even help clear OBDII errors?
George-CZ is offline   Reply With Quote
Old 12-17-2018, 03:09 PM   #9
Rogue Leader
There is actually a little adapter you can buy that plugs into your lighter that can keep the system charged enough to not lose the computer's memory. Or if you have a battery tender you can leave that connected to the 2 battery cables.
Normally you shouldn't run into this issue, i think I'm just having bad luck.
Old 12-17-2018, 03:32 PM   #10
George-CZ
George-CZ's Avatar
Is there a link as an adapter looks?
I had a similar bad luck with my 78.
The engine had to build three times before it worked.
Old 12-17-2018, 03:54 PM   #11
Rogue Leader
Like this
https://www.amazon.com/Powerbuilt-64...XRJ5WDT1V8FK7Q
Or you can use this to connect to another car or a car battery
https://www.amazon.com/VSTM-Emergenc...JJ1VFE9794MC56
Old 12-17-2018, 04:03 PM   #12
George-CZ
George-CZ's Avatar
Like this
I understand.
Thank you for explaining and trying to help.
Old 12-17-2018, 08:34 PM   #13
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
My Camaro didn't pass after I had the battery replaced 2 years ago.
The highway trip for ~100 miles @70MPH fixed it for me. So hopefully what your friend does will reset the sensors.
Last fall/winter it was hit while parked and in the shop for 4 weeks. I never got the battery over 12.4V again, even on a tender for weeks. The positive post under the hood was uncapped, so I know they jumped it.
It's worse this winter so I'm going to bring it in for a battery check (still under warranty). Last week I received the emission test notice (due by the end of March). So I took it in a couple days later and passed. This week or next I'll bring it in for the battery. It's getting worse with our cold weather.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 12-17-2018, 10:18 PM   #14
Rogue Leader
Tried this tonight, it did not work.
I think one of my O2 sensors is bad even though its not throwing a code. This is the live data from my code reader.
Note the highlighted SHRTFTB1S2% is N/A
Also note B2S2 is stuck on 99%
I think the downstream sensor in bank 1 is bad. That would be the same bank that had the valvespring failure. As far as I know S1 was not replaced, but it seems to be working. The cat was definitely replaced, but the sensors I'm fairly sure were not.
EDIT: Ok so that N/A is Short term fuel trim. Note B2S2 lists as 99.2 that is correct and mans the car is burning nearly all fuel. The fact B1S2 reads N/A may mean the O2 sensor is bad. Strangely enough it is reading back voltage in the correct range however.
Anyone know this better than the bit of research i just did?
ny state inspection
