07-18-2019, 12:00 PM | #1 |
Drives: 2015 2SS Stock Join Date: Sep 2018
Ball park please
With my L99, LS9 cam and TSP 1 7/8 headers what estimate whp can I expect with a F-1x Procharger at 10psi? I might be able to get a steal on one locally.
2015 2SS auto. AGP twin turbo, LS9 cam, BTR 660 springs, LS9 Gaskets, ARP studs, 400lph UPP fuel system, MBRP XP 3” cat back, 305/30 Micky Thompson Sport comp tires. 12” Fockford fosgate P1, Rockford Fosgate 600w amp.
07-18-2019, 12:52 PM | #2 |
Drives: G8 Join Date: Mar 2012
Shot from the hip? ~650rwhp
Sent from my Pixel XL using Tapatalk |
07-18-2019, 12:57 PM | #3 |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
Why did you use 1 3/4 headers instead of the 1 7/8"?
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
07-18-2019, 01:49 PM | #4 |
I didn't, it was a type o' my bad.
07-18-2019, 02:39 PM | #5 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
If you have been dynotuned now and have your HP number with the cam, add a little more than 200whp. Rough guess. I gained 200 on the whipple at 10psi from stock, stock cam
07-18-2019, 02:51 PM | #6 | |
Drives: 2010 Black 2ss Camaro SS Join Date: May 2010
agreed....your sig says 367rwhp....this before the cam? if so, you will be around 600.....you will also need a torque converter for a cam.
ZL1 10 spokes,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 102mm TB, Dr Phil Tune,Borla Atak
