![]() Drives: 2014 1ss camaro Join Date: Jul 2017
harmonic balancer
my next modification for this winter will be a new balancer. im limited in knowledge of these. parameters are i run on the street longevity is a concern plus performance. any suggestions will be appriciated. price is somewhat of a concern, but not so much a deal breaker. just like you guys. im looking for the best bang for my buck. no power adders just NA. headers cold air etc. looking to keep her smoove at all rmp's i remember back in the 70's in the army i was riding in a gi's 70 rs he got on it and i watched his harmonic balancer fly down the street in front of us. i'll go with arp bolt and possibly pin the balancer to the crank if nessesary. all input and experience is greatly appriciated, the oldman.........
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I can't speak of in terms of experience, but I did just buy a Fluid Dynamics balancer buy have not installed it yet. It seems to be one of the best ones out there.
https://www.summitracing.com/parts/FLU-760111
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
Are you thinking about doing this as preventive maintenance or are you seeing some "wobble" that causes you alarm? If you're going to be in that area for a cam, timing chain, or oil pump upgrade I'd say definitely change/improve your balancer but otherwise I'd put this in the "it ain't broke, don't fix it" dept. That balancer is held on by a large bolt torqued to 240 ft-lbs. It's not gonna fall off anytime soon.
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
I ran an ATI balancer N/A and running the same one F/I. We only do ATI at the shop. Nothing against Fluidamper.
More to come. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
You only need to pin the crank if you are running a blower, and even then it's a choice. I run the Innovators West which is a bit more expensive and if you let anyone work on your car, make sure they understand how to take it off. I had someone try to use a two jaw puller which did a little damage to the outer appearance. All fixed now, but not something I enjoyed discovering while working on the car. Innovators is aluminum and lighter than stock. They also make underdrive and overdrive balancers.
2010 SS - Kind of an On3 kit, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
#6 |
i was changing it just for piece of mind. thinking i would help with longevity of the balance of the motor. does the stock one keep the balance in check? not familiar with it. i mean if its ok not to replace ,ok. i was wondering about the benefits as compared to stock.
#7 |
People change them because they are moving up in power level. Stock one will likely outlast the engine if you are not revving it high.
#8 | |
![]() ![]() Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
