#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > V8 LT1 Engine, Exhaust, and Bolt-Ons
Old 01-21-2017, 02:20 AM   #1
aa406079
Drives: New : 2017 SS 1LE Old: 2012 TTRS M6
Block/ Oil / Engine heater?
Simple question... does the LT1 come with one?
If no... are there aftermarket solutions?
( nothing via search)
aa406079 is offline   Reply With Quote
Old 01-22-2017, 01:14 PM   #2
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
http://www.camaro6.com/forums/showthread.php?t=461600
Looks like it's not available on models equipped with the LT1 or LT4.
Not sure why they'd offer it on the LT models and not the SS/ZL1. That's an option I would like to have.
vtirocz is offline   Reply With Quote
Old 01-22-2017, 02:02 PM   #3
MMC
MMC's Avatar
Drives: CGM 2SS/RS, 1987 & 2014 Silverado
Block heaters are worthless because they don't turn on until it's 0 degrees out,
the reason for this is if the OBD2 reads that the block is warm and it's should not be, there must be a bad sensor reading and it will set a code and give you a check engine light. I have a block heater in my Silverado and was surprised they wont operate above 0 degrees as the ones in older trucks I have owned would operate at any temp. but the new ones are thermostatically controlled.
MMC is offline   Reply With Quote
