04-05-2017, 08:51 PM | #1 |
Let the ***ding begin
Drives: 2011 Camaro 2SS Join Date: Aug 2015
Dyno'D Today and well...
Well after a long winter and a self install LSA i was finally able to see the fruits of my labour
Started out as a pretty much stock 2011 camaro 2SS ls3 (manual) ORDER OF INSTALL - magnaflow resonated muffler delete cat back - gm new lsa supercharger - lingenfelter solid isolator - adjusted the boost valve by eye as it was way off from factory - zl1 fuel pump (what a pain to install) - tr6 plugs - all gm accessories for a clean install - Zl1 intercooler pump (home made harness-GM 110.00 OUCH!!!) - ZL1 injectors - Home made CAI - Stret scene lower grill ducts - Windshield washer relocate - AEM wideband - Fuel pressure Guage - Dual intake air temp guage - Many exterior accessories, GM WHERE POSSIBLE - Home made idler bracket Wish i would of kept a detailed thread as i had quite a few gandy DIY that would of no doubt helped some people Still have my line Lock and accessory fuse box to install plus a few other things Please guess what my horsepower should be on a dynojet with 93 octane and a very safe, smooth tune |
04-05-2017, 08:54 PM | #2 |
Pic
04-05-2017, 08:59 PM | #3 |
Pics
04-05-2017, 09:08 PM | #4 |
Drives: 2013 ZL1 Join Date: Jan 2015
Nice install but fairly mild. I would guess around 530whp
2013 A6 ZL1
04-05-2017, 09:17 PM | #5 |
Little north of that, Extremely happy so far
Also big thanks to anybody that sold me parts on this forum, as it does get a bit expensive here in Canada especially with the poor exchange rate and shipping As a side note, IAT was installed in the lid by breaking away from the MAF sensor Tuned accordingly, and most likely safer albeit a little power might be sacrificed |
04-05-2017, 10:09 PM | #6 |
Drives: Z06 wannabe Join Date: Feb 2015
Over 530 without Headers or Cam on Stock Pulleys? or did I read over something?
That seems strong for sure.
Apex Focused
04-05-2017, 10:38 PM | #7 |
Yes
All stock Settled on 537 HP. With 530 torque After dyno, took a street ride and done a few minir tweaks I know jts not crazy horsepower, but its the most i have had and to ne it pulks like a freakin freight train Next project, slightly smaller pulley along with upgraded clutch. |
04-05-2017, 10:39 PM | #8 |
Pic
04-05-2017, 11:01 PM | #9 |
'It's an experiment'
Temps are close to the correction factor temp, not bad at all...
Congrats! SAE Smooth 5 would give the correct #. Probably a bit lower, but very nice indeed... -Don
747 RWHP 794 RWTQ
04-05-2017, 11:09 PM | #10 |
Thanks Don
Went through your very detailed build thread and pulled a lot of great info for my use Great work and nice car! Ron |
04-05-2017, 11:39 PM | #11 |
Glad it was helpful!
It is A LOOOOOOOOONG read ;o) Ported # Thursday for me! -Don
747 RWHP 794 RWTQ
04-06-2017, 02:48 AM | #12 |
"BEASTM*DE"
Damn good job and numbers...If you do a pulley upgrade, go with the lower and balancer, less work, unless you plan to port the snout if replacing the upper...Again very good job looks clean and professional...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
04-06-2017, 07:46 AM | #13 |
GPI Sales Consultant
Nice. I'm surprised no headers - these cars love them NA and under boost they've got be worth quite a bit of grunt. Either way that's a stout number, ZL1 injectors probably a little more room left to get closer to 600whp with the additional mods. There are always additional mods...
Got a question about a GPI product? Feel free to shoot me a message! |
04-06-2017, 07:56 AM | #14 |
Where did you get the gas door cover? I want one.
