04-30-2020, 09:13 PM | #1 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Backward LSA LS3 swap
So it's pretty common to add an LSA blower to an LS3, but have you ever seen an LSA with an LS3 blower?
I bought a Whipple 2.9 for my LS3 but ended up having a cracked cylinder liner that sent me down an interesting path. I ended up finding a slightly used LSA short block with some new AFR heads and managed to build it for the Whipple. The results below were much better than I expected. This is the new LSA Whipple setup vs my LS3 with long tubes and an intake last year. Sent from my Pixel XL using Tapatalk
05-01-2020, 06:45 AM | #2 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Yes people upgrade from the LSA SC all the time. That's usually when you see the used lsa set up for sale. The lsa is a pretty small SC in comparison to the aftermarket world.
05-01-2020, 07:36 AM | #3 |
I guess I never spent enough time in the ZL1 forums. I thought I did a pretty good job making it all work.
05-01-2020, 08:50 AM | #4 |
What are the differences in the block? I know the bottom end is a little stronger on the LSA but isn't the block the same? Were you able to swap your stuff from your ls3 to bolt on the to lsa or did you run into problems? Those are nice numbers on 8psi.
05-01-2020, 09:05 AM | #5 |
I wish Whipple made an LSA fitment blower. I'm sure that combo has a lot left in it too.
05-01-2020, 09:07 AM | #6 |
Block looks the same but can definitely see that the pistons are lower compression. I was able to use all of my LS3 accessories. Fortunately the ATI LS3 damper is keyed so it bolted nicely to the crank and everything lined up to use the LS3 belt spacing. I'll definitely need more fuel before I can turn up the boost but I'm really happy with where it baselined.
05-01-2020, 09:12 AM | #7 |
If I made it work, I'm sure you guys can...it has tons of room left but it cost me way more than planned so I'm going to have to wait before I can turn it up. Besides, I have to get used to it.
05-01-2020, 09:38 AM | #8 | |
05-01-2020, 10:12 AM | #9 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
LSA blocks are supposed to be stronger than LS3 blocks. Here is what one source says the difference is.
LS3 has a Cast Nodular Iron crank, LSA has a forged crank LS3 no piston oil squirters, LSA have piston oil squirters LSA block is 20% stronger than the LS3 short-block LS3 Block is a deep skirt cast A356-T6 ALUMINUM ALLOY with pressed in cylinders. LSA and LS9 Block is a deep skirt cast 319-T7 ALUMINUM ALLOY, with cast-in-iron cylinders and uses 4-Bolts per cylinder to affix the cylinder heads to the block, just as does an LS3. |
05-01-2020, 10:18 AM | #10 | |
05-01-2020, 11:20 AM | #11 |
Drives: 1970 Pontiac Firebird L8T Join Date: Dec 2016
larry_g I'm glad you liked the setup. My son delivered the motor to you for me. The LSA short block also has piston oil squirters to help keep the pistons cooler. The block is stronger than a standard LS3 block, and the crank is forged also.
05-01-2020, 11:53 AM | #12 |
I thought you were on here. It worked out really well, thanks.
05-01-2020, 12:43 PM | #13 |
No problem.
The 1LE has the ZL1 fuel pump doesn't it? I'd say you have that thing maxed out now. Should be able to make even more power if you decide to turn the boost up some. I'd say it's a blast to drive with where you are now, even if you never go for more boost. |
05-01-2020, 01:31 PM | #14 |
Some good #'s. You got one of the best tuners in the business
5.98 @ 115mph
