05-02-2020, 10:10 AM | #1 |
Valkyrie14
Drives: Chevrolet Camaro SS Join Date: Mar 2020
RTV on snout for LSA
Last night I remounted the snout on the LSA lower. I used black RTV. When I lined up the coupler I had to use a bit of force to get the lower and the snout to come together enough to thread the bolts. The surfaces came together faster than I wanted. I then hand tightened the bolts and an hour later torqued to 22 ft pounds.
This morning when I look in side the snout I see a series of stalactites hanging down and a raised bead on the bottom where the snout mounts up. Is this a problem? I know nothing should go into the rotors and I am concerned that over time the RTV May break loose and fly int there. I only ran a thin bead of RTV. I can take it apart clean it up and do it again. But first I wanted to see if this is normal and no matter how many times I do it this will happen.
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
05-02-2020, 05:06 PM | #2 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
I don't know the lsa or what you are talking about. I assume it's supposed to be sealed with rtv and there's no gasket? Maybe rather than running a bead you can make a thin film with your finger so you don't get the excess? Or If it's accessible trim the excess with a razor
05-02-2020, 05:45 PM | #3 | |
Valkyrie14
05-02-2020, 06:03 PM | #4 |
Loctite 518 Anaerobic gasket maker works good, and you can wipe away excess...
Sent from my Pixel 2 XL using Tapatalk |
05-02-2020, 06:50 PM | #5 |
Valkyrie14
Thanks for the tip
05-05-2020, 07:15 AM | #6 |
Valkyrie14
So I took off the snout and cleaned it again to remount. I used less RTV this time and smoothed it flat with my finger this time. It still beaded up when I tightened up the bolts, but not near as bad. The beading is small and didn’t drip into a stalagtite situation inside the snout. Not factory but will have to work.
05-05-2020, 12:39 PM | #7 |
Drives: 2009 ZR1 Join Date: May 2010
It was never an issue with my ls9
05-05-2020, 07:12 PM | #8 |
Valkyrie14
Did you have the RTV bead up inside? I don’t think it will break loose over time, heat and forced air.
05-05-2020, 07:56 PM | #9 | |
Another thing you could do is go buy a sheet of gasket material and cut it to fit. I have done that several times on other things. My 112mm throttle body came with a gasket so I didn't have to RTV it. When I had the 108mm, I had to RTV the adapter and TB. Last edited by blake-b; 05-05-2020 at 08:16 PM. |
05-06-2020, 08:42 AM | #10 |
You don't need much rtv. A little will always squeeze out of the side. That just means the snout is nice and flush against the blower.
05-06-2020, 11:51 AM | #11 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
For an application at work, I've actually rolled on Permatex ultrablack with an acrylic roller to join two plates that seal small CNC pathways machined in one plate. In this application it holds over 100psi without leak, and the thickness of the permatex is negligible (no squeeze out).
My point is: you just have to make sure you get a uniform coating, but permatex can be very thin and still work perfectly. Side benefit: no squeeze-out!
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
