Old 05-07-2017, 05:50 PM   #1
iownedu
Drives: 2014 Camaro Z/28
Just installed my wickerbill, doesn't seem right.
Look how low it is, this is on the highest setting. I think the lowest setting would make it almost non-existent.
You can also see the outer edges of it hangs below the OEM spoiler.
I followed the GM instructions that clearly stated to have the template lined up with the BOTTOM edge of the spoiler.
Is this how your guys looks?
2014 Camaro Z/28. Last Pre-Production car, #69. White without A/C, 1 of 4.
2008 Mercedes AMG C63
Longtubes, Intakes, Wheels, Coilovers, Tune
2006 Lamborghini Gallardo SE
Gated Verde Ithaca
Heffner 1000TTG
iownedu is offline   Reply With Quote
Old 05-07-2017, 06:12 PM   #2
69L48Z27
69L48Z27's Avatar
Drives: 2015 Z/28; 1969 Camaro SS
I believe that looks right.
69L48Z27 is offline   Reply With Quote
Old 05-07-2017, 07:07 PM   #3
DemonZL1
199
DemonZL1's Avatar
Drives: like a granny
no, rivnuts installed too low, unfortunately.
2023 Silverado LZ0 Duramax
2021 Shock SS 1LE A10
www.youtube.com/@DemonWorksPerformance
Anderson composites coupon code : Demon
DemonZL1 is offline   Reply With Quote
Old 05-07-2017, 07:09 PM   #4
Crushinator
Crushinator's Avatar
Drives: '15 Z/28 #783
Yep, I just checked mine. Looks close, but I think they may be a bit low. The second rivnut washer looks like it sits below the spoiler. On mine, that same washer is above the bottom edge of the spoiler. No one's gonna notice unless you tell them. I wouldn't worry about it.
2015 Z/28
A/C and audio
Crushinator is offline   Reply With Quote
Old 05-07-2017, 07:11 PM   #5
YOLO Z/28
YOLO Z/28
YOLO Z/28's Avatar
Drives: 2014 Z/28
Mines definitely higher. I dont have a pick with the OE wicker because the 2 Piece aftermarket one was my first upgrade.
2014 Red Hot Z/28, CTF car #39/69. HCI, Supercharged, boltons.
2006 SRM GTO, exhaust, VMR V701 wheels (SOLD)
2002 Bright Red Trans Am WS6: HCI, exhaust, tune, Konis, UMI sways, LCAs, Track bar, STB, 2" boxed steel SFCs (SOLD)
YOLO Z/28 is offline   Reply With Quote
Old 05-07-2017, 07:25 PM   #6
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
Definitely looks a bit low
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 05-07-2017, 07:31 PM   #7
YOLO Z/28
YOLO Z/28
YOLO Z/28's Avatar
Drives: 2014 Z/28
This is a picture of mine. The lower part of the dog ear sits flush with the base of the spoiler and doesn't hang low like yours. If all you care about is looks, I wouldn't worry. If you were actually trying to achieve more stability around the track, then you probably won't get the same down force.
Old 05-07-2017, 07:33 PM   #8
D2M
D2M's Avatar
Drives: Z/28
I cheated and moved the template up slightly when I installed mine.
D2M is offline   Reply With Quote
Old 05-07-2017, 07:52 PM   #9
YOLO Z/28
YOLO Z/28
YOLO Z/28's Avatar
Drives: 2014 Z/28
Haha I would've done the same if my car hasn't already had the wicker installed!!!
Old 05-07-2017, 08:00 PM   #10
iownedu
Comparing mine to all the pics from GM on the web, it looks like I indeed installed it correctly.
But imo it seems the OEM install is a bit low, I'd like it up about 3/16 of an inch from where GM recommends.
Gated Verde Ithaca
Heffner 1000TTG
Old 05-07-2017, 08:06 PM   #11
YOLO Z/28
YOLO Z/28
YOLO Z/28's Avatar
Drives: 2014 Z/28
Interesting. Mines a CTF car like yours, but had the wicker installed from the factory by GM. Whoever put mine on didn't follow the instructions correctly lol
Old 05-07-2017, 08:43 PM   #12
68camaroz28
68camaroz28's Avatar
Drives: 68 Z28, 69 Z28, 2015 Z28
Followed the instructions on mine and it came out this way but remember cheating it just a very small amount so wicker bill did not stick down below other spoiler, but again small incremental move what I remember.
68, 69 & 2015 Z/28's
68 Z/28 Restoration Thread on Team Camaro
http://www.camaros.net/forums/showthread.php?t=182584
68camaroz28 is offline   Reply With Quote
Old 05-07-2017, 08:59 PM   #13
s.hammer
Drives: 2015 Z/28
I think you installed it correctly with regards to the instructions, but I cheated it up like D2M...
s.hammer is offline   Reply With Quote
Old 05-08-2017, 09:20 AM   #14
rcandiloro
rcandiloro's Avatar
Drives: 2018 ZLE
Here is mine.....factory installed.
rcandiloro is offline   Reply With Quote
