06-30-2019, 11:50 AM | #1 |
USA-1
For roll on performance on an L99, is keeping VVT or LS3 conversion better?
Hey guys,
So I am like 99.9% sold on using a VVT cam in my L99, BUT, I feel like the LS3 conversion makes more HP. Knowing this, if most of my runs are highway roll-ons, would it make more sense to do a LS3 conversion?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
06-30-2019, 01:08 PM | #2 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
It’s a TQ v HP thing. Based on what I know, similar cams in both versions might net you more bang for your buck with VVT. If it’s DD then you might like the lower RPM torque of the VVT. If you track it for ET then you might like the straight cam and it’s upper end pulling power. But there’s all the variables of the AFM parts if you’re not pulling heads, etc. And that’s what I’ve learned here.
06-30-2019, 01:31 PM | #3 |
USA-1
Speaking to the choir here! As I said i'm like 99.9% sure i'm going with VVT.
I'm just curious how a non-VVT SS1 vs a VVT SS1 cam on an L99 would perform during a roll-on on the highway.
06-30-2019, 01:31 PM | #4 |
Drives: '23 LT1 A10 Join Date: Oct 2015
Every engine builder around me says no to vvt. Not sure why.
24 LT1 M6 Sharkskin Metallic
14 Mazda Mazda3 S Grand Touring (Daily) |
06-30-2019, 01:33 PM | #5 |
USA-1
Honestly I think they may just not know how to work with it. Everything I've seen (even the dyno sheets) says that unless you are going full race build or need the most HP possible, VVT is the way to go.
06-30-2019, 01:38 PM | #6 |
USA-1
Good article on why to keep it! http://www.superchevy.com/how-to/eng...n-iv-v-engine/
06-30-2019, 03:05 PM | #7 | |
376 cubic inches of fun
So...peak HP for an engine occurs at the peak of the curve that plots torque as a function of RPM. However, a flat torque curve delivers more HP at lower RPMs and delivers more acceleration. Comparing the Gen 5 engines, the VVT L99 generates way more HP between 2000 and 4000 RPM than the peaky LS3 and has the advantage on the drag strip. Here's another way of looking at it: your car's speed is a measure of its kinetic energy. To deliver energy, you need sustained torque. In a torque vs RPM curve, the energy delivered is the area under the curve. Therefore, a flat torque curve delivers more energy than a peaky torque curve, if the max torques are similar. Gotta love the calculus. |
06-30-2019, 03:12 PM | #8 |
USA-1
Ok, so adding all that into the equation, if the LS3 conversion has more peak HP than the VVT one, how does that affect roll on performance?
06-30-2019, 03:25 PM | #9 | |
Comparing stock L99 and LS3 quarter mile elapsed times, the L99 is consistent the winner. Peak HP alone is pointless in a drag race. Again, it's all about the area under the curve. |
06-30-2019, 03:44 PM | #10 | |
06-30-2019, 05:10 PM | #11 |
Would going from a full bolt on L99 with 3.91s to a LS3 conversion "stage 1" cam and the same mods have a noticeable decrease in low RPM power? Two builders local said that the power is not noticeable or no one has ever complained about a lack of low power.
06-30-2019, 05:43 PM | #12 |
USA-1
I don't see you having a decrease in power going from bolt-on to a LS3 conversion, but I think the consensus is you are leaving power on the table if you don't do VVT. Not sure if you saw this, but this has me sold on VVT...among other things. http://www.superchevy.com/how-to/eng...n-iv-v-engine/
06-30-2019, 05:52 PM | #13 | |
06-30-2019, 06:05 PM | #14 |
USA-1
I think because it's easier to do. I've seen some posts from Jannetty were he says he prefers the more simpler setup with less moving parts.
