Old 02-07-2018, 03:28 PM   #1
Foxrus14
Drives: 2018 ZL1 1LE
Send a message via AIM to Foxrus14 Send a message via Skype™ to Foxrus14
Problem with all codes popping up
Just put 325 wide tires on the back. Dealership returned the car and when I started it back up, all the codes came up. EBrake, abs, traction control off, and asks to service the power steering.
Dealership cleared codes and as driving home they all popped up again. And power steering is out. 2015 ZL1 with 40,000 miles
Anyone have any experience with this?
Foxrus14 is offline   Reply With Quote
Old 02-07-2018, 03:45 PM   #2
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Don't have the codes but sounds like you have a loose ground. There's plenty here in the forum around steering failure.
ZMEnow is offline   Reply With Quote
Old 02-07-2018, 06:04 PM   #3
danvillekidd
2013 ZL1
danvillekidd's Avatar
Drives: 2013 ZL1 m6
First thought is too big of a difference between the front and rear tire diameters. After that,
danvillekidd is offline   Reply With Quote
Old 02-07-2018, 06:58 PM   #4
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I have experience with avoiding dealers like the plague for exactly this kind of sh!t. Best of luck!
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides-
2014 ZL1 M6 Red Hot | Tons of mods
2004 CTS-V M6 Silver | Many mods
1995 Corvette M6 Torch Red | A few more mods
1992 Camaro M5 White | A few mods
RobZL1 is offline   Reply With Quote
Old 02-08-2018, 05:21 AM   #5
rmcbee
rmcbee's Avatar
Drives: 2013 ZL1
codes
I had all those codes pop up using an AeroForce gauge. Had to turn off, unplug, plug in again and then turn on and computer reset itself?
rmcbee is offline   Reply With Quote
Old 02-08-2018, 07:45 AM   #6
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Check your battery's resting voltage, sometimes it's as simple as that. Another check might be whether or not the dealer did an ECM update. I'm assuming you're tuned, and I would always ask the dealer to avoid trying to install an update. I'm betting it's related to a voltage issue though.....wouldn't think going from a 305 to a 325 would cause that much of an issue.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 02-16-2018, 12:32 PM   #7
Fraxum
Fraxum's Avatar
Drives: a M6 LT1 ordered From Becky!!!
This ^ (most likely, loose ground 2nd)
My ZL1 had problem #2 and GM bought it back and trashed the car I think.
I still miss my 5th gen ZL1.
Old 02-16-2018, 12:36 PM   #8
hammdo
'It's an experiment'
hammdo's Avatar
If the tires are taller than 1" over what the ECM thinks it should be, can set the codes. Also, verify grounds as mentioned..
-Don
747 RWHP 794 RWTQ
