05-26-2011, 07:23 PM | #1 |
Drives: the Camaro as often as possible Join Date: Jul 2009
Need help with Solo
I've got the Solo w/ J pipe setup and have 2 issues.
Question 1 -- I've got some decent drone at around 2500-2700 RPM. The engine will sit right around that range when climbing hills @ around 40 MPH or so, and it also goes through that range during any mild acceleration. How would I go about adusting it out? Do I slide the whole j-pipe, or just the caps at the ends? In or out? Question 2 -- I've adjusted the exhaust twice now to try and get the tips centered in the openings, but they won't stay there. I've loosened the front and middle clamps, gotten things adjusted, but they go back over time. It seems like the hangers aren't bent right or something, because I have to really twist and push to get it in the right position, and then tighten it down. Now the driver side tip is vibrating against the valance. Suggestions? The exhaust has broken in now and it sounds pretty sweet. If I could resolve these 2 issues I'd be very happy. |
05-26-2011, 07:44 PM | #2 |
knows 2 facts about ducks
http://www.camaro5.com/forums/showthread.php?t=102075
At the end of the first post their is a table that tells you what J-pipe lengths cancel out drone at certain RPMs |
05-26-2011, 07:48 PM | #3 |
Drives: 2 LT/RS YELLOW, AUTO., VIN NO. 602 Join Date: May 2010
I also have a alingment problem with the driver side and it's almost impossible to ajust without taking the diffuser off.
So instead of trying to bend the pipe I bought an SS diffuser that I will install soon. The pipes holes are much bigger and there will be plenty room left. As for the drone I don't have that issue on mine, maybe contact Solo Performance.
05-26-2011, 08:17 PM | #4 |
Let me know how it goes with the SS diffuser, I have the exact same issue.
Solo Mach X-LLT Exhaust
Vararam Intake |
05-26-2011, 08:30 PM | #5 |
Drives: 2011 Camaro 2LT/RS Join Date: Jan 2011
I had the same problem, but I just took a tire iron and wedged it between the pipe and the hanger and was able to bend the hanger just enough so it sat centered in the valance.
K&N Aircharger, BBK longtube ceramic headers w/high flow cats, Solo Mach X-LLT Catback exhaust, Street Scene body kit and Trifecta tune.
05-27-2011, 08:19 AM | #6 |
Drives: 2010 Camaro 2LT RS Join Date: Nov 2008
Solo installed mine, and I watched them do the adjustment to center the tips. What they did was this:
They put a long bar into the tip, heated the hanger with a torch until it was red, the bent the tip. When they had it where it needed to be, they sprayed water on the tip to cool it. Yes, they had it red hot while the hanger was in the rubber. |
05-27-2011, 11:11 AM | #7 | |
INJACC
Drives: 2010 CGM 2LT/RS AUTO Join Date: Jan 2009
Member of 'Club Elite' #70
2LT/RS Auto / Solo HFC / Solo Mach X-LLT J-Pipe / JBA Headers Shorty CAI - Cold Air Inductions / VMAX TB / Trifecta Tune Hotchkis Max Strut Brace / Blade Dovetail Spoiler / Elite Catch Can ACS T3 Hood Ports / T2 Bumper Ports / T2 Splitter / ACS T1 Led Light Kit ACS Rockers / ACS Composite Hood Liner / ACS Upper Rear Quarter Ports ACS Front Wheel Mud Flaps / ACS Rear Wheel Mud Flaps / Vitesse Throttle Controller Pedders Drop Suspension / BMR Lower Control Arms / Style 41 ZL1 Wheels / Oracle Afterburners / Oracle Concept SMD Side markers Complete SS Brembo Brakes Set |
05-31-2011, 07:15 PM | #8 | |||
05-31-2011, 07:38 PM | #9 |
Drives: 2011 RJT 2LT/RS Convertible Join Date: Nov 2009
For my vert I had Solo Performance/Muffler Man shop in Buffalo do the install since there was some issues with the cross bracing. They ended up heating and bending the hangers and everything was great. On my Coupe I did the install and I also bent the hanger slightly to get the tips centered.
Depending on the V6 it seems the j-pipe adjustment is slightly different. But after a few moves of the caps there is absolutely no drone on my coupe. On the vert they set it up correctly right out of the shop.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
06-05-2011, 08:40 PM | #10 |
Any news on whether the SS diffuser worked and/or pictures?
Vararam Intake |
06-06-2011, 06:12 AM | #11 |
INJACC
Should be installing this afternoon(I hope)...with another C5 V6 too.
06-12-2011, 10:14 PM | #12 |
How'd the install go?
Vararam Intake |
07-20-2011, 05:46 PM | #13 |
Does anybody have some pics of an SS diffuser with the Solo tips? There is one for sale around me, wondering if i should go for it
Vararam Intake |
07-20-2011, 06:06 PM | #14 | |
Similar Threads | ||||
SOLO Performance Exhaust Product Videos for the Camaro | GOINGSOLO2 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 6 | 08-10-2010 10:20 AM |
New Tunable Solo System | mrbrans5 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 55 | 08-06-2010 01:23 PM |
My Solo Mach X to Corsa Review Read On! | 55Designs | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 25 | 07-11-2010 09:35 AM |
SOLO PERFORMANCE makes two EXCELLENT Exhausts for the 6.2L V8 | Xmicro_SS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 106 | 04-19-2010 09:11 PM |
SOLO Performance Camaro Exhaust Sound Clips Compilation | GOINGSOLO2 | V8 Bolt-Ons & Tunes | 29 | 04-11-2010 08:11 PM |
