03-20-2016, 09:26 PM | #1 |
Drives: 2010 camaro ss Join Date: Jun 2010
He differential bushings
I these bushings up for sale. Only used them for like 3k miles. $100 shipped. Will post pic soon.
03-20-2016, 09:53 PM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Why you replacing them???
Orange Krush II
03-20-2016, 09:53 PM | #3 |
Offset differential bushings
03-20-2016, 09:59 PM | #4 |
Im selling the car and they made a bit of noise from the differential because of the true trac that I have in it. I also had solid subframe bushings. It was much easier to change these out than the cradle bushings. I loved them but I had people thinking something was wrong with my differential but nothing is wrong with it. It was just a combination of all solid bushings plus the true trac. My buddy has these in his 1le with no true trac and stock cradle bushings and its not noisy at all. These help keep your axles safe on hard launches
03-23-2016, 09:17 AM | #5 |
They are in great condition. Great way to keep your axles safe and lower 60ft
03-23-2016, 07:02 PM | #6 |
SICC
Drives: 2014 2SS1LE Summit White Camaro Join Date: May 2014
Who makes these and how hard of an installation were they? Do they effect the handling of the car?
Sent from my HTC One M9 using Tapatalk |
03-23-2016, 08:40 PM | #7 |
Hendricks engineering makes these.
Check this out another member installed these. http://www.camaro5.com/forums/showthread.php?t=411997 |
03-29-2016, 02:51 PM | #8 |
Bump
04-07-2016, 09:30 PM | #9 |
Bump
05-02-2016, 09:05 AM | #10 |
Bump
05-02-2016, 01:45 PM | #11 |
Counting down the days...
Drives: Black 2011 2SS/RS Join Date: Mar 2011
Interested. PM'd.
Tick Performance Custom Cam w/ support mods/BBK LT Headers w/ midpipes/Straight Exhaust/Airaid Cold Air Intake/ZL1 Driveshaft/ZL1 Differential/Hendrix Engineering Offset Bushings/ZL1 Axles/BMR Rear Subframe Bushings/BMR Toe Rods/Carlyle Racing 15" Conversion/Jannetty Winsheild Bottle Scoop/Forgestar 15x10 Beadlocks wrapped in Mickey Thompson Radial Pros
05-02-2016, 10:24 PM | #12 |
New pics
05-03-2016, 10:29 PM | #13 |
Sold
05-03-2016, 11:20 PM | #14 |
SS
I have a set still wrapped up if anyone else needs a set
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
