Old 04-07-2019, 06:38 AM   #1
Dogmeat
Dogmeat's Avatar
Drives: 2011 RS
Oil Question
I know yer spozed to use 5w30 in this car ('11 6 cyl), but I have certificates I can use to get Harley oil free....it's 20w50, but I'm wondering if that's gonna cause any problem? I know it'll increase the friction due to a heavier oil, but other than that, the only thing I can think of it that it'll use a minimal amount of xtra gas......but the engine duzzn't know what it is, so am I wrong in thinking that there's really no problem in using this? Car only has 36500 miles.
Proud Owner Of '11 Camaro RS & '79 'Vette w/ 383 Stroker
Dogmeat is offline   Reply With Quote
Old 04-07-2019, 06:48 AM   #2
STALKER
STALKER's Avatar
Drives: 2014 Camaro SS Spring Edition
Absolutely not. One thing you don't want to do is cut corners when it comes to oil. Taken directly from the manual:
Viscosity Grade
Engine Oil Additives/Engine Oil Flushes
SAE 5W-30 is the best viscosity grade for the vehicle. Do not use
other viscosity grade oils such as SAE 10W-30, 10W-40, or 20W-50.
2014 Camaro SS Spring Edition 2SS
LSX440
LSX Block, MAST Black Label Heads, Ti Intake Valves, Diamond Pistons, Callies Crank & H-Beam Rods, Cam Motion Cam, LS7 Lifters & Pushrods, CHE LS7 Rockers, Ported Mamo MSD Intake, NW 102 TB, Z28 CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Kooks Z28 3" Cat-Back, Z28/1LE Shifter, ZR1 Clutch, Katech Lightweight Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler, 20" Z28 Wheels with Nittos.
STALKER is offline   Reply With Quote
Old 04-07-2019, 06:54 AM   #3
Tajefe Couple
Tajefe Couple's Avatar
Drives: Never just fly under the radar
If I understand its not like the old days. In short if you decide on other oil weights it will not lubricate in the areas it needs to properly. Can and will cause premature engine failure by eventually causing parts to gum up and not be properly lubricated. Those weights are very important especially in newer rides.
Old Skool
Tajefe Couple is offline   Reply With Quote
Old 04-07-2019, 02:00 PM   #4
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS LS3 Swapped A6
The main issue with the wrong weight oil in the newer engines is they are clearanced and designed for use with 5w30 oil or whatever oil is recommended. If I was running an LFX or LLT engine, I would definitely want to use what was designed to run in the engine. Some people will say it is just for CAFE and fuel economy reasons, and I am sure that's a part of it, but why risk it?
You will see guys with built bottom ends running different weight oils, but that is usually fine since those engines were built with such oils in mind.
Stock engine? Use manufacturer recommended oil. Just my humble opinion.
2010 CGM Camaro 2SS LS3 Swapped A6 - GPI LS3 SS1 .647/.638, (224/237, 112 +4, 7º overlap) on CamMotion 8620 core, Melling HV 10296 oil pump, CHE trunnion upgrade, stock heads milled .015, TSP longtube headers (Catless), FM Outlaw axle back/X-Pipe, Stage 2 PTB, Vararam OTR CAI, Mike Norris Gen 2 catch can + GM 1LE clean side separator, 160º stat - Megan Racing adjustable coilovers, Firestone Firehawk Indy 500s - Tuned by Ryan @ GPI via HP Tuners
Old 04-07-2019, 05:48 PM   #5
EMB135Driver
Jedi Master
EMB135Driver's Avatar
Drives: Boeing 757/767+2010 IBM 2SS
Penny wise and pound foolish....saving a few bucks on oil to grenade your entire engine cause the oil will not circulate properly.
EMB135Driver is offline   Reply With Quote
Old 04-07-2019, 08:04 PM   #6
lionssfan
lionssfan's Avatar
Drives: 2010 2ss camaro
I worked for one of the big three in engineering. I've seen in some cases catastrophic failure going with the wrong engine oil. this is one area i wouldn't cut corners.
2012 zl1 stock 7000 miles
2010
TVS2300, BTR cam PD stage 3, ID1050 injectors, CHE bronze trunnions, 7.400" pushrods,.660" lift platinum springs, Titanium ret, Zl1 fuel pump, Kooks LT headers, High flow cats, Roto Fab CAI, Corsa exh., Mellings oil pump, HD chain, ls2 damper, all synthetic, BMR control arms, zl1 toe link, BMR cradle mounts, W/bottle relocation, air scoop deflector, Hennessy wheels, two piece rotor, morimoto fogs, DRL harness, coilovers, Heads up install, mgw shifter, slps splitter, slp spoiler, zl1 side skirts, painted strips, debadged, tinted, 2018 emblems.
Edit Signature
lionssfan is offline   Reply With Quote
Old 04-07-2019, 08:27 PM   #7
Welker2
Ret AF, cancer survivor
Welker2's Avatar
Is using the wrong oil worth the risk just to save a few bucks? Several years back I had an '87 Callaway Twin-Turbo Corvette; because of the mods Callaway had done, it took 5-50w. This was labeled on the oil filler tube cap, as well as posted in large print on the side of the oil cooler closest to the oil filler tube. About a month after I sold it, I got a call from the new owner asking if I had ever had any engine issues, which I told him no (never did, was one of the best running, maintenance free vehicles I have ever owned). When I asked why, he said he had a catastrophic engine failure, the car was in the shop and insurance wouldn't cover the cost. In talking with him about possible reasons, found out that he changed the oil shortly after buying it, he used 10-30w. A few days later, he called back to inform me the mechanics pretty much confirmed the failure was due to using the wrong oil.
Old 04-07-2019, 09:54 PM   #8
15RS2NV
Ponies are for girls
15RS2NV's Avatar
Drives: 2015 RS LFX Red Hot (G7C)
20W50 is WAY to think for these cars. I used to us that in an older car that had 300K and i street raced it. Never use in a car less that 200k, ever.
H&R 1.8/1.7” drop, Overkill 80mm, intake ported by AFS, 1" insulator MACE, Accel Super Coils, THR cai, JET MAF sensor, Hurst shifter handle, GPP strut tower brace, CI ice cube tray hood vents (functional)
15RS2NV is offline   Reply With Quote
Old 04-08-2019, 05:57 AM   #9
Dogmeat
Dogmeat's Avatar
Drives: 2011 RS
Thanx to all for the replies.....confirms what I was thinkin'....I'll continue to use 5w30!!
Old 04-08-2019, 07:09 AM   #10
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
And BTW if you still had a warranty using the wrong grade of oil and letting the dealer know it instantly voids your warranty...………..
2013 2SS/RS LS3 M6 ,CRT, NPP, Forged 428 ls3 stroker, GMPP ported heads, Katech chain, Mast windage, Cam Motion Cam, trunnion upgrade, Stainless Power headers HFC, CAI w/kit, Vmax PTD, Fluidampr, Powermaster xs 9509 starter, BMR strut brace,trailing arms, toes, bushings, Crossfire wheels & extreme contacts, elite catch can, clutch reservoir, dash/body LED, DRL rewire, Sparks badges, Forza 3way, tint, MRT louvers, ZL1 spoiler, MGW short throw, Monster dual LT1S clutch, bleeder, support, high vol pump, Speed hut shift light, ACC flames stripes, Driven ls30 oil, NGK TR6IX , Granatelli wires.
Old 04-08-2019, 07:32 AM   #11
EMB135Driver
Jedi Master
Lol.....Nice back-peddling......Your original post indicated you saw nothing wrong with using it.....”just a little more fuel...engine won’t know difference.....really no problem using this”.
Old 04-08-2019, 07:33 AM   #12
Russell James
Russell James's Avatar
Sell the free Harley oil on Craig's list. You could use 10w30 in the summer, but I wouldn't go thicker.
Old 04-08-2019, 12:09 PM   #13
Avenging Orange
Avenging Orange's Avatar
Though I have used it in many application over the years...and never suffered "catastrophic engine failure". I do agree with the statements regarding modern technology. Oil (dino) will penetrate in all the needed areas, no matter how hard you try to stop it.
Bottom line, for a V6 daily driver, no.
2010 Inferno Orange 2SS/RS M6 Black Leather,Sun Roof, OBX Headers, Haltech CAI , non synthetic fluids, Mike Norris tuned 419/413, BMR Cradle/Diff/front Radius rod/lower control arm bushings/1" lowering springs, DSE 32mm fe4 rear sway bar. GM fe4 shocks/struts/LCA's, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20.
Avenging Orange: 42 years of not buying into the Hype........and damn proud of it!!
https://youtu.be/9JD9it6SmB8
Old 04-08-2019, 01:00 PM   #14
mickss
mickss's Avatar
Drives: 2010 Camaro LS-M6 67 Chevelle Wgn
Engineers put a lot of time and research in designing a engine so it will meet the manufacturers specifications for their warranty so if they state a specific type of oil it`s a good idea to do as recommended. I`m not about to second guess someone who has way more experience than I have.
Free Trade is not Fair Trade
I am, we are INDIVISIBLE
Invictus, By William Ernest Henley
mickss is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
