Old 07-30-2019, 09:00 AM   #1
V8only
Drives: 2012 camaro 45th 2ss/rs Centri SC
Octane booster? Tune keeps reverting And have to perform fuse pull. Cali gas
Hi all. I live in California. 91 octane is as good as it gets. When I first bought my 12ss I performed the fuse pull and it worked wonders. Fast forward a couple years and I have a small centrifugal Supercharger.. All else stock. Recently I noticed all my power was gone. I confirmed this when I ran my brothers stock 14 and got beat.
Last night I pulled fuse 5 and 20 just to see if that would fix my issue and it has. It would seem this car doesn't like California gas. If I added octane booster to each tank would that help? Any other suggestions?
Thanks
Jeremy
-2012 Camaro SS 45th M6-Kraftwerks Supercharger
-2003 Avalanche z71-6" on 35's. DD 290k miles
-66 mustang fuel injected resto-mod
V8only is offline   Reply With Quote
Old 07-30-2019, 09:05 AM   #2
Russell James
Russell James's Avatar
Yeah but not practical. A good tuner tunes for the fuel available. I'd take it back to the tuner with the 91 in the tank. Set the tables to perform best on that. Which is going to a struggle with a supercharger, high compression, and low octane.
Old 07-30-2019, 09:56 AM   #3
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
Most likely your car is knocking because of the boost, and because it's knocking it's falling down to the low octane table.
Did you get a new tune after the boost was added?
2012 Camaro 2SS/RS | 1968 Camaro SS | 2000 Monte Carlo SS | 2018 Regal TourX
ChibiBlackSheep is offline   Reply With Quote
Old 07-30-2019, 09:58 AM   #4
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Don't put a band aid on it. Why not just tune for 91?
Forged 376, E85, milled GMPP ported heads, Night Fury, Vmax TB, GPI rod mod manifold,Improved racing,Melling,ATI, DSE, DW, BTR, Smith Brothers, McLeod twin RXT, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Vararam OTR intake,Tick,Elite CC,Kooks headers/HFC,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017,Continental Extreme Contact, Nitto555R
Black_SS10 is offline   Reply With Quote
Old 07-30-2019, 10:00 AM   #5
PowertoLove
Banned
Drives: A Sneaky Fast Camaro
Water injection system might help a lot.
PowertoLove is offline   Reply With Quote
Old 07-30-2019, 02:18 PM   #6
V8only
thanks...it was tuned for 91 after the supercharger..I'll just take it back to him and see what he thinks
Jeremy
Old 07-30-2019, 03:15 PM   #7
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
I agree with others, take the car back to the tuner. Something isn't right if it's kicking back down to a different fuel table. Also, you might consider switching gas stations. Maybe the guy running the fuel truck doesn't know how to put premium into the premium tanks at the gas station?
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
pyroguy is online now   Reply With Quote
Old 07-30-2019, 04:08 PM   #8
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
I was under the impression that the tuner usually copies the high octane table to the low octane spot so they are the same. That is why the fuse pull is usually irrelevant on tunes cars. Maybe yours didn't do it.
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 07-30-2019, 04:13 PM   #9
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6
Most tuners won't do that , if you get bad gas and don't realize it's knocking you will destroy your motor
davidscamaro is offline   Reply With Quote
Old 07-30-2019, 04:15 PM   #10
davidscamaro
They often reduce knock sensitivity but almost never copy the high over to the low table
Old 07-30-2019, 04:19 PM   #11
davidscamaro
I might be the odd one out but if I needed octane booster I would just use it every tank. What's the big deal if it stops the knock and let's you get your power ,then use it
Old 07-30-2019, 04:28 PM   #12
ChibiBlackSheep
Yeah, you do it ONLY when tuning to dial things in, but then you put the low-octane map back in. It's bad to completely take it out of the tune. You never know if you get bad gas, or if a mistake happens.
Octane booster really doesn't do much. When you read a bottle that raises octane 5 points, that's not making 87 octane 92, it's making 87 octane 87.5.
That's why some people mix with race gas or 100 octane when they want to boost their octane.
Old 07-30-2019, 04:44 PM   #13
davidscamaro
There are some booster that do 30 points, Lucas or nos brand I believe
But you are right the 4 dollar a bottle stuff don't do anything
Old 07-30-2019, 08:46 PM   #14
Rob10CamaroSS
Drives: 2012 ZL1 Redline Phase 4
You don't want octane booster period, you want Concentrated Race Fuel.
These are the two I'm familiar with
Race Gas
or
Torco
I've used Torco for a good 10 years or more on "many" different performance vehicles. I've had numerous street Vehicles through the years that were set up to be ran on C12 or even C16. I'm a sucker for a 800 to 1000 HP Street Car or Pick Up, waaaaaay to many to talk about LOL....
Torco won't destroys your Cats or 02 Sensors either, only down side is orange spark plugs, LOL
$20.00 for 32oz, I can get 93 octane so I generally would add a can to each fill up (10 to 15 gallons). Ya it's an extra $20.00 but still a hell of a lot cheaper than running it 24/7 on 105, C12, or whatever....
Might be worth a try ?
Unfortunately with 91 octane you would have to use more, it all depends on your target octane
93 octane chart
91 octane chart
I get them on ebay for @ $20.00 a pop and free shipping when you buy a 6 pk
2012 ZL1 w/Redline PHASE 4-ZL Performance Package
Rob10CamaroSS is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
