Old 08-05-2019, 07:54 PM   #1
frey.199
Drives: 2010 Camaro 2SS
Lifter Suggestions
Looking to upgrade my lifters, but I'm looking for suggestions. I've heard great things about Johnson lifters and know the LS7 that come stock with the LS3 are really good as well. Possible future boost and looking for good quality with practically zero failure reports. Installing large cam TSP stage 3 SC. Still up in the air about changing lifters, but want to get a rough idea of what I'm going to spend for some if I do. Willing to spend the money for good lifters, but obviously prefer to save if anyone knows of something good like Johnson, but less expensive. All input is appreciated and part numbers would be awesome!
frey.199 is offline   Reply With Quote
Old 08-05-2019, 08:13 PM   #2
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
All Ive ever ran is LS7s
Old 08-05-2019, 08:16 PM   #3
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Ls3 and ls7 are the same lifter. I would just replace them OEM when you do the cam.
Forged 376, E85, milled GMPP ported heads, Night Fury, Vmax TB, GPI rod mod manifold,Improved racing,Melling,ATI, DSE, DW, BTR, Smith Brothers, McLeod twin RXT, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Vararam OTR intake,Tick,Elite CC,Kooks headers/HFC,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT05R
Black_SS10 is offline   Reply With Quote
Old 08-05-2019, 08:35 PM   #4
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
I used comp cams 850-16 and am happy with them.
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 08-05-2019, 08:42 PM   #5
Dbunch9
GPI sells cheverolet performance racing lifters that i think I'm gonna try next time i need lifters. Theyre like $100 cheaper than the Johnson lifters and tested up to 8000rpm
Dbunch9 is offline   Reply With Quote
Old 08-05-2019, 09:00 PM   #6
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
Standard LS3 will do just fine
Sent from my SM-N960U using Tapatalk
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 08-06-2019, 06:15 AM   #7
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
I have those and spin to 7800 rpm
11.079 @ 122.99mph
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 08-06-2019, 07:27 AM   #8
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
Theres more to it then just what lifter. Honestly just about any lifter you buy with your cam kit from a reputable vendor is good stuff. You can set them up many ways. I have a engine builder friend who uses nothing but LS7 lifters set in the middle of their travel for dirt track cars that see 8200 RPM and at the end of the season they are thrown away with the engine refresh. The GM racing lifters are good option. I will say at 63k miles the retainer that holds the plunger in was coming apart on my stock lifters. So they do have a life span once you beat on them. I have Johnson short travels with axle oiling in my motor currently.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 08-06-2019, 07:47 AM   #9
Russell James
Russell James's Avatar
You can't have... I want the best... but cheap.
If you want an upgrade, call Johnson and ask for the COPO std travel drop ins. There is a reason they are used in the COPO motors. No they are not cheap. Take advantage of someone else's millions in R&D to find the best.
Standard travel if you desire quiet. Short travel if you need every last tenth of a hp, but at a price of a little noise. Carefully choosing the correct pushrod length will also help with less noise/hp/wear.
Old 08-06-2019, 09:25 AM   #10
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
The LS7 style lifters have worked great for us and are on most of our builds.
We sell, ship install and tune all the hottest brands for your late model Camaro. Get amazing deals on Corsa, Borla, AWE, Kooks, SW, Magnuson, Whipple, Procharger, Roto-fab, CAI and more. Pm or call us for your Camaro forum discount, install rates and appointments.
Juiced1 is offline   Reply With Quote
Old 08-06-2019, 11:35 AM   #11
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
If I did another cam it would be a low lash solid with Jesel Rockers.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 08-06-2019, 12:25 PM   #12
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
i went with the chevrolet performance lifters as well when i did the cam.
12499225
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 08-07-2019, 06:37 AM   #13
PhantomBlack
Drives: 2014 Camaro 2SS
I did the same with my cam Chevrolet Performance lifters 12499225. Which is the same as the OEM LS7/LS3 lifters I believe?
PhantomBlack is offline   Reply With Quote
Old 08-07-2019, 07:01 AM   #14
ZEN357
ZEN357's Avatar
Drives: 1991 Z/28 Convertible
I would go with Melling. They make very good lifters.
https://www.jegs.com/i/Melling/689/J...791+4294829509
ZEN357 is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
