Emblempros
Old 08-23-2019, 03:27 PM   #1
revo1059
revo1059's Avatar
Drives: Black 2012 ZL1
Front rotor ring replacement
Have micro cracks in my front rotors. I assume just the ring can be replaced. Stock the best cost effective option? Anybody have the P/Ns for them?
revo1059 is offline   Reply With Quote
Old 08-23-2019, 04:17 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
0 ring replacements — rotors are a balanced set — only option as of now is new rotors...
~$285 each on amazon...
-Don
747 RWHP 794 RWTQ
Old 08-29-2019, 01:34 PM   #3
revo1059
revo1059's Avatar
Crap. Ok. OEM the best bang for the buck?
Old 09-04-2019, 02:26 PM   #4
Russell James
Russell James's Avatar
Sometimes pad material can build up and look like cracks. Unless the rotors were cooked to red glowing hot, or have beauty holes in them. I've seen plenty of cracks around the holed rotors, but the solids unless really overcooked shouldn't be cracked. Anyone put on ceramic pads? Those can build up layers that look like cracks, but just pad material smeared on.
Old 09-05-2019, 07:24 AM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I'm looking for 2pc rotor hardware my self already have the hats just hardware and figure out what rings I wanna use.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Suede Steering wheel, short throw shifter. Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, C7 GS Calipers, PAFDT Solid Cradle bushing, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs.
Old 09-15-2019, 08:50 PM   #6
FASTFATBOY
Drives: 2013 ZL1
Coleman rotors will build you a set
FASTFATBOY is offline   Reply With Quote
Old 09-17-2019, 12:20 PM   #7
RyangAsh
Drives: 2014 ZL1
Is this the same fastfatboy from LS1tech? waz up?
RyangAsh is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
