Old 09-17-2016, 02:53 PM   #1
Chris0222
Drives: 2010 Camaro SS
Key Release
Hi All,
My 2010 SS has a problem. Sometimes I stop put the Transmission in PARK make sure the break is on and turn the key off and the car will not allow the key go in the off position and I can not get it out. I have been carrying 2 keys so I can lock the door. All the electronics stay on and it will drain the btry overnight. Any suggestions??
Chris
Chris0222 is offline   Reply With Quote
Old 09-17-2016, 03:11 PM   #2
wrtowman
wrtowman's Avatar
Drives: 2011 Camaro 1SS
Bad tumblers would be my guess. Just replace the ignition.
2011 SGM Camaro 1SS/RS A6 - Vengeance Racing built/tuned. 590RWHP/560RWTQ, ADM LSA Conversion, 2.5 Grip-Tec, ZL1 fuel pump, ADM FPCM, FIC1000, VRPD2 Cam and LS3 Conversion with all the internal goodies, American Racing 1 7/8 Headers, no cats, SW Retro Cat Back, ADM Intake, AFCO HX, Varimax Pump, Rotofab Reservoir, B&M Transmission Cooler, VMAX TB, Elite Engineering CC, BMR LCAs, Trailing Arms, Toe Rods, DSS 1000hp axles, ZL1 Bumper and Sideskirts, Night Owl Halos, Matte Black 20" Rohana RC-22 with 20x10-275s/20x11-315s, R1 Concept Premier Drilled/Slotted Rotors, Hawk Ceramic Pads.
wrtowman is offline   Reply With Quote
Old 09-17-2016, 03:21 PM   #3
ChrisBlair
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3
Is the steering wheel locked whenever the key will not come out?
ChrisBlair is offline   Reply With Quote
Old 09-17-2016, 05:07 PM   #4
Scalded Dog
Scalded Dog's Avatar
Drives: 2011 1LT
My kid called me in a panic recently: He could not remove the key from the ignition, and couldn't turn the key either. I instructed him to give the steering wheel some muscle, and try the key again. He thinks that I am a car god.
Another possibility: When my battery went south, one of the first symptoms I found was that the key would not release from the ignition. Replaced the battery, haven't had the key problem since. Is your battery still at 100% functionality? If it's original in your 2010, the time is coming very soon... if it's a reasonably new bat, then your problem is probably elsewhere...
Scalded Dog is offline   Reply With Quote
Old 09-17-2016, 05:14 PM   #5
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
+1 this happens to me if I park with the wheel turned. I just have to turn the wheel a bit until it's off the lock and it works
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 09-18-2016, 01:28 PM   #6
Chris0222
No it does not.
Old 09-18-2016, 01:29 PM   #7
Chris0222
I tried rotating the steering wheel and it didn't help. but it was something I had not tried, Thanks.
Old 09-18-2016, 01:32 PM   #8
Chris0222
I have a newer btry. It charges and holds a charge. I think if that was the problem, hooking it up to a charger would fix it. It doesn't.
Old 09-18-2016, 02:00 PM   #9
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
Is the key still stuck ? If so read your owners manual , there is a key release in the steering column for when they get stuck . Then I would take it to a dealer and get it fixed .
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
Old 09-18-2016, 02:34 PM   #10
coolcamaroZ28
Camaro Addict
coolcamaroZ28's Avatar
Drives: 2010SS/1995 Z28/2005 CTSV/2007 TBSS
Sounds like your neutral safety switch. Try slamming it into park as hard as you can and see if that works...
coolcamaroZ28 is offline   Reply With Quote
Old 09-19-2016, 01:26 PM   #11
REDDNOZE
REDDNOZE's Avatar
Drives: 14 summit white 2SS/RS
i had this problem after i took shifter apart, to remedy it i would pop/flick the shift knob button im guessing i did not seat it properly after paint and shifter boot install. if it quiet enough you can hear it engage then turn key back to off position
If it happens and I have time i will make a video
REDDNOZE is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
