03-31-2019, 03:09 PM | #1 |
Drives: L99 Join Date: Nov 2018
L99 transmission issue
Need to go little higher with revs for car to start moving...
03-31-2019, 04:50 PM | #2 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Could be the torque converter...or low fluid...a few different things.
More to come. |
04-01-2019, 07:57 AM | #3 |
How to measure the gearbox fluid level on this car?
04-01-2019, 09:32 AM | #4 |
SomeguyK
It's a pain in the ass, since there is no factory dipstick.
More to come. |
04-02-2019, 04:24 AM | #5 | ||
Drives: 2012 1LT SIM Camaro Join Date: Sep 2012
Here is a video which explains how to verify proper fluid level in a late model GM auto tranny. No dipstick because once the fluid level is correct, short of a direct leak, its not going anywhere. |
04-16-2019, 04:42 AM | #6 |
No fault codes or problem in driving...
04-16-2019, 01:08 PM | #7 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
Tancho, check the fluid level in the transmission per the video above. Before doing that, while fluid is cold, stick your finger in the hole. Look at and smell the fluid, it should be red and not smell burnt. If black and/or smells burnt = not good. You may be lucky that things will be ok with a fluid and filter change, if not your transmission/converter needs to be repaired.
04-24-2019, 08:30 PM | #8 | ||
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
04-24-2019, 09:00 PM | #9 |
'It's an experiment'
747 RWHP 794 RWTQ
04-26-2019, 07:51 PM | #10 |
Nice, Hammdo, but if that SOB plug is so hard to get to, how easy is this ‘fix?’
04-26-2019, 08:08 PM | #11 |
It wasn’t too bad really. I popped the plug out pretty quickly. Whole install took about 45 minutes...
-Don
747 RWHP 794 RWTQ
