02-17-2018, 10:12 PM | #1 |
Drives: 2014 Camaro LS V6 Join Date: Dec 2014
Camaro Halo lights condensation.. Halo works but HID doesn’t
Hey everyone two days ago I noticed my passenger side HID bulb is out. the halo rings power up but HID doesn’t it. The headlight is heavily condensed but I can’t seem to find a puddle of water within the headlights just droplets inside. I ordered a replacement I found on amazon matching the same specs and company and the HID did not power up. I have yet to test the bulb with the other drivers side headlights ( which do work) so I will see that tomorrow morning . I thought about taking it to Chevrolet dealership but I don’t know how much they’d charge me for it. I found used RS headlights for $280 so i don’t know if I should just replace it.
Any advice you guys can supply? |
02-18-2018, 12:11 AM | #2 |
Camaro- Life Member
Mine did this last year randomly for a couple of months. Bought a new bulb, no change. Swapped bulbs side to side (both factory bulbs), No change, original dead bulb worked in other side. What I ended up doing was leaving that bulb out on a good hot day, letting it air dry and then put the original bulb back in. No more issues, no moisture, no non lighting issues since. Been through pretty bad rain storms, washed hundred times, etc.
Im wondering if the bulb gasket was getting pinched or possibly dried out and shrunk or something. There for a while it would have tons of moisture then disappear on its own (visually at least) then reappear with the slightest temp changes. Maybe take the bulb out and use a hair drier on low for a bit to try to dry out the housing. Just make sure to protect the bulb, and dont let it cool before reinstalling the bulb as it would probably draw moisture back in pretty quick.
15 2SS/RS LS3 M6 Summit white
16 200 40mpg Vivid Blue Pearl 19 Tahoe 5.3 Boring Grey 91 Camaro RS 305 TBI 700R4 85 Corvette - TBD 05 Envoy 4.2 4x4 |
Thread Tools | |
