sjm autoprod
Old 02-28-2018, 09:04 PM   #1
briancamaross
briancamaross's Avatar
Drives: 2011 ss 2ss auto camaro
Looking for rotors
What’s a good brand for rotors, I do run 1/8 and 1/4 a bunch. Do I need drilled and slotted or just slotted?
2011 2ss white Camaro mods are texas speed stage 4 cam 235/239 Texas speed 2inch headers no cats magna flow bullet mufflers gpi rod mod ,circle d 4000-4200 5c stall. 3.91 gears vararm cai power wedge.
briancamaross is offline   Reply With Quote
Old 03-01-2018, 01:06 PM   #2
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Plain face rotors are my preference, but if you never see a road course, slotted and cross drilled will be a touch lighter.
Old 03-01-2018, 05:48 PM   #3
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
I currently stick with stock...now if you drag racin a 2 piece rotor with an alum hat would be the way to go...this stock sh1t is heavy....peace
2010 SS 2SS M6-Spectre CAI-JET TBS-JBA Shorty Headers-ARH H/F Cats-Doug Thorley axle back-MSD 12v coil harness mod-PAC 1218's-BTR 3/8 7.4 push rods-Powell Machine bronze rocker bushings-Prothane motor mounts-Prothane rear sub-frame inserts-BMR Trailing Arms & bushings-1LE 3.91's-1LE axles-Ford S-spring posi-mod-Tune by RDP dynoSteve!(Woot)-Daily Driver-120K!-12.7 at 112-1.9 60'(3.45's)-BFG Comp-2 Street Tire-stock size on ZL1 reps(20x8.5)(20x9.5)-DR's Nitto NT05R(305/45) on Motegi MT120 18x9.5-12.1 at 114-1.7 60'(3.91's) All work by me...
Old 03-05-2018, 10:54 PM   #4
TWOFORTYZ
Drives: 2015 Camaro 1SS 6M
I also greatly prefer full faced rotors, I've seen surface cracking near the holes and slots when abused. Drilled and slotted offer no benefit other than weight savings from my experience.
For drag racing the cheapest brakes are more than sufficient. There is not enough thermal load to overheat even crappy pads. I seem to be enjoying stock pads and rotors, I may go with generic or aftermarket (ie cheap) rotors and stock pads later depending on price.
TWOFORTYZ is offline   Reply With Quote
Old 03-08-2018, 05:05 PM   #5
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro SS
Generally speaking drilled rotors are a thing of the past as a way to relieve gassing from pad material. Modern day pad compositions have this issue addressed in reputable brake pad companies.
Pro-tuned is offline   Reply With Quote
