Rick@Livernois
Old 05-05-2018, 07:30 PM   #1
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Rear seat delet
Who here has done a rear seat delete? Looking for ideas or what people have done. Thanks.
Technostalgia tail lights,MGW shifter, Vararam tuned intake,JDP Reservoir,Ideal MC,Tick,Elite catch can,Kooks LT, Kooks HFC,Flowmaster Outlaw,VMAX TB,Tuned by DynoSteve,Mantic 9000,DSS aluminum driveshaft,Pegasus subframe bushings,BMR trailing & toe arms,Z28 upper control arm bushings,Zl1 rear sway bar,Prothane radius arm inserts,BMR steering rack bushing,Goodridge brake lines,Ridetech HQ level 2 coilovers,3.9gear,Trutrac,billet caps,1k axles,1LE diffuser,Havoc spoiler,SSclones,20in CCW 505A,Continental Extreme Contact Sports
Black_SS10 is offline   Reply With Quote
Old 05-05-2018, 07:35 PM   #2
jc615
jc615's Avatar
Drives: Camaro and Sierra
Buy the kit. What more you want to know?
jc615 is offline   Reply With Quote
Old 05-05-2018, 07:38 PM   #3
Black_SS10
SomeguyK
Black_SS10's Avatar
Is Shrader the only one that makes a kit? Thanks for your help...
Old 05-05-2018, 08:24 PM   #4
cnrad
cnrad's Avatar
Drives: 2011 Cᴀᴍᴀʀo
Go through this thread: https://www.camaro5.com/forums/showthread.php?t=523954
Look at Jay's posts. Best rear seat delete I've seen for the Camaro. Maybe try contacting him and see if you could purchase one from him? Probably wouldn't be cheap, but it would be well worth it. Or if you're crafty you can try making something similar, or find a shop to do it.
cnrad is offline   Reply With Quote
Old 05-05-2018, 09:13 PM   #5
jc615
jc615's Avatar
I don't know if it's the only but it's the one I bought and have used for about 4-5 years
Old 05-05-2018, 09:22 PM   #6
Black_SS10
SomeguyK
Black_SS10's Avatar
I will take a look, thanks!!!
How do you like it?
Old 05-05-2018, 09:33 PM   #7
jc615
jc615's Avatar
Works fine. I installed it and took it out twice to get into trunk. Not really much to it. Two seatbelt bolts for top piece and bottom.
Old 05-05-2018, 09:34 PM   #8
krisprz2010camaross
SoCal HT5
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers LS3
I just installed the shrader rear seat delete. Looks very clean!
YouTube:BlackandyellowCamaro
Instagram:kris__perez
LS3 conversion
Vararam intake(tune model)
Kooks 1 7/8" LT headers & cats delete
Corsa ZL1 3" exhaust
Addiction Motorsports Dyno Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
Taylor racing spark plug wire sleeves
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 05-05-2018, 09:41 PM   #9
Black_SS10
SomeguyK
Black_SS10's Avatar
Does the carpet match? Also does it flow well with the interior? Doesn't look out of place? Hard to tell with Schrader pictures.
Old 05-05-2018, 10:41 PM   #10
jc615
jc615's Avatar
It's pretty close and flows fine. I have inferno orange/black leather and IMO it looks fine. Not sure I'd pay full price. Got mine used for about $100
Old 05-05-2018, 11:02 PM   #11
krisprz2010camaross
SoCal HT5
Rear seat delet
Yes, they only have black carpet available now and it still blends in perfectly. If they still had the grey carpet option it would look factory. I’m surprised the Z28 didn’t have a rear seat delete option. Then we all could have purchased an oem rear seats delete lol
LS3 conversion
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
Circle D Stall
GM 3.91 gears
Old 05-06-2018, 12:05 AM   #12
Black_SS10
SomeguyK
Black_SS10's Avatar
Thanks for the insight. I'll prolly go the Schrader route. It a $240 right now. Unless someone knows cheaper.
Old 05-06-2018, 04:52 AM   #13
ticowarbird
BOHIC
ticowarbird's Avatar
Drives: 2010 Camaro SS "Enola"
Pretty basic.
ECS blower kit, Alky Control meth Injection, RPMtransmission 4L80E, QTP cutouts, line lock, Circle D converter, GPI modified LS3 intake manifold, BoWhite PTB, ARH LTs/exhaust, TSP VVT3 cam and ported heads, SLP 160 Tstat, NGK TR55 plugs, ADM FPCM, dual pump, ID1300 injectors, flexfuel sensor, 18" wheel setup, ZL1 3.73 differential, DSS 1-piece aluminum drive shaft axles, Koni yellow shocks/struts, BMR Suspension…FOR NOW.
ticowarbird is offline   Reply With Quote
Old 05-06-2018, 09:12 AM   #14
Black_SS10
SomeguyK
Black_SS10's Avatar
Thanks Tico. Hard to tell in the picture, but it looks like the carpet on the delete doesn't match well to the car. Or does it?
