Old 12-01-2019, 09:52 AM   #1
Dirtmod66
Dirtmod66's Avatar
Drives: 2010 Camaro SS
Cam question about mileage
Wanting to get a stage 3 cam and a new converter; I've already have new 3.91 and tru-trac.
How would car do on a 2000 mile trip? Not worried about gas mileage. Is that too long a trip on engine and trans for a straight drive? ( non-stop)(24-28hrs).... please no speculations!!!
Dirtmod66 is offline   Reply With Quote
Old 12-01-2019, 10:28 AM   #2
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
As long as everything is installed correctly, it will be no problem.
More to come.
Black_SS10 is offline   Reply With Quote
Old 12-01-2019, 11:11 AM   #3
1fast
8.60 @ 157 @ 4200lbs
1fast's Avatar
Drives: 2010 Gen 5
Parts
Good parts and top notch converter no issues at all.
2010 camaro twin turbo 8.60 @ 157 full weight 4200
1fast is offline   Reply With Quote
Old 12-01-2019, 12:07 PM   #4
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
This^^^
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 12-01-2019, 06:45 PM   #5
Bandit63
Bandit63's Avatar
Drives: 2011 Camaro SS
I have that set up and would not be afraid to drive it anywhere
MRR M228 Wheels, Circle D 3200 Stall, 3.91 Gear, Texas Speed VVT 3.2 Cam, CHE Rocker Arm Bushings, Texas Speed Headers, No Cats
Bandit63 is offline   Reply With Quote
Old 12-01-2019, 07:29 PM   #6
InFiD3ViL
InFiD3ViL's Avatar
I guess the only downside to long mileage trips like that would be that you would be that much closer to having to change your valve springs. ie, 25k miles service interval
But if that was a huge worry, why drive the car at all? amirite? AMIRITE?!?
Old 12-01-2019, 10:48 PM   #7
Roader
Drives: Camaro
I did little over 2k mile round trip with a tsp 2 cam and 3200 stall with no issues. Wife was able to cruise along at 90mph no issue as well
Roader is offline   Reply With Quote
Old 12-02-2019, 12:53 AM   #8
Bo White
Bo White's Avatar
Ive got 30k miles on my springs with a th400 swap and 4.10s
I might change them next summer. I might not lol.
Old 12-02-2019, 09:42 AM   #9
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
I saw your new PB, Bo, congrats! We always seem to be neck and neck. Nice work sir
Any videos on the new pass?
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 12-03-2019, 10:39 AM   #10
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
I have tsp 231 236 640' and done many 14h-22h road trip (roundway) and it's all good. Very low fuel consumption too. Ls are the goods.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 12-04-2019, 08:54 AM   #11
Athletics101
Athletics101's Avatar
Drives: 5th Gen L99
Stock motors and transmissions have cams and torque converters too. There should be no problems if temps and fluid pressures are in check.
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
Athletics101 is offline   Reply With Quote
Old 12-04-2019, 09:28 AM   #12
Chris49066SS
Drives: 2010 SS L99
Stock torque converters don't slip and produce the same heat that larger converters do though. And again, it depends on the converter that the OP chooses, but a proper converter for a Stage 3 cam really oughta have a good tranny cooler to keep the temps down. It will be ok for the drive, but its better to invest a couple $$$ on a nice cooler so you're not messing anything up that doesn't need to be. I run the ADM cooler and tranny temps never get above 180, with a Circle D 5C converter
Old 12-05-2019, 09:28 AM   #13
Dirtmod66
Dirtmod66's Avatar
Thanks-
I plan on putting a really good trans cooler on it (Fluidyne), I used them in my other race cars and never had a problem with one.. I will be doing the speed limit on I40. LOL
Old 12-05-2019, 09:59 AM   #14
Chris49066SS
Drives: 2010 SS L99
Originally Posted by Dirtmod66 View Post
Thanks-
Yeah man, better safer than sorry
