Old 12-29-2019, 07:52 AM   #1
Dirtmod66
Dirtmod66's Avatar
Drives: 2010 Camaro SS
Lifter question...
Looking for lifters and a set came up that were branded Jegs; has anyone used them? Who makes them for Jegs? Also what about Crower lifters? What's the best lifter under $300? Don't want to pay Johnson prices if I don't have to....
Dirtmod66 is offline   Reply With Quote
Old 12-29-2019, 08:15 AM   #2
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Ls7...
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 12-29-2019, 08:29 AM   #3
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
From what I see, the Crower are just as much or more than Johnson. Dont put Jegs lifters in your engine or cheap stuff. Lifters are not easy to change so put good ones in it.
Johnson 2110 lifters are going for 430 dollars now, for what you get spend the extra 130 bucks.
There are these GM performnac lifters that are a step up from the LS7 right around 300 bucks https://gwatneyperformance.com/produ...ters-88958689/
If money is that tight and you cant wait to save up, run the LS7 lifters like Clark said.
Lifters are very important to durability, performance and noise of your valve-train. Put good ones in and save money somewhere else.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 12-29-2019, 08:37 AM   #4
Bo White
Bo White's Avatar
All Ive ever ran are stock lifters/LS7.
Old 12-29-2019, 08:41 AM   #5
Dirtmod66
Dirtmod66's Avatar
12499225 is that the number for the LS7 lifteer?
Old 12-29-2019, 08:43 AM   #6
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
The stock ls3/ls7 lifters are fine, what I am running as well. The actual GM performance lifters, different part number, are a tad better being tested to 8,000rpms.
More to come.
Black_SS10 is offline   Reply With Quote
Old 12-29-2019, 08:45 AM   #7
Black_SS10
SomeguyK
Black_SS10's Avatar
Those are the ls3/ls7 factory lifters in a set of 16.
More to come.
Old 12-29-2019, 10:03 AM   #8
Dirtmod66
Dirtmod66's Avatar
What about Cam Motion lifters?
Old 12-29-2019, 10:26 AM   #9
Black_SS10
SomeguyK
Black_SS10's Avatar
What about them? They have a bunch of different types. The LS replacement ones are most likely reboxed GM ones, ie whoever makes them.
More to come.
Old 12-29-2019, 11:12 AM   #10
Dirtmod66
Dirtmod66's Avatar
It was a simple quesion are they any good? Lifters could be like batteries, 1 company makes 90% of batteries for everyone; just rebranded. Lifters could be the same except for the Chinese ones...Maybe your just paying for a name, maybe not! I don't know that's why I asked the question....
Old 12-29-2019, 11:35 AM   #11
Black_SS10
SomeguyK
Black_SS10's Avatar
But you didn't ask if they were any good, just what about cam motion lifters. I answered the question, you just reiterated what I said. You're over thinking this.
More to come.
Old 12-29-2019, 11:36 AM   #12
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
GM Performance lifters 11k miles no issues, spin mine to 7700 RPM
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 12-29-2019, 03:17 PM   #13
zz430camaro
Drives: 2015 1LE
The are made by Morel or Johnson.
Old 12-29-2019, 04:05 PM   #14
InFiD3ViL
InFiD3ViL's Avatar
I was looking at those when I had my rebuild done, but went with regular LS7. Those are tested in excess of 7k right? I think a lot of people glance over or miss those when shopping and assume it is just another listing of the regular LS7 lifters. Are they similar design to the 'Cadillac' lifters?
