12-03-2019, 09:47 AM | #1 |
Delete mag ride
Hey, searched the forum and not finding anything. Has anyone done a mag ride delete and knows the resistor values needed to trick the computer? I know there are lots available that do this plug and play but they are ridiculously expensive for 8 resistors. I need to delete the shocks/struts and the ride height sensors. I cannot incorporate these in my project so I want to trick the computer so I don't have annoying DIC messages. Thanks.
12-03-2019, 12:28 PM | #2 |
Drives: 2013 ZL1 Join Date: Dec 2015
I don’t have an answer. Years ago I wanted to go to coilovers and got in a conversation with the president of afe and mentioned that his mag delete was expensive and he said he had a set that for some reason he couldn’t sell and he would let me have them for cheap. That was three years ago and next week I’m doing my 15” conversion and will finally use them. I also came across TEC2 which you can use found it on YouTube. I heard you can go to a dealer and get it turned off? And of course phasetek sells them.
09-18-2020, 06:40 PM | #3 |
Bump... still needing these resistor values if anyone knows?
09-19-2020, 12:06 AM | #4 |
Drives: 2015 ZL1 Join Date: Jun 2015
09-19-2020, 09:09 AM | #5 |
Godzl1a you have tried the 2.7 OHM resistors with success? When I measure my struts I get 1.4 OHM.
09-19-2020, 07:51 PM | #6 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
I would give this a try or the 100watt unit linked above if this burned out:
09-19-2020, 08:02 PM | #7 |
I also need to bypass the ride height sensors as well...just need to determine the voltage output at normal ride height and what resistor will output that voltage from the 5v reference
09-20-2020, 10:44 AM | #8 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
i thought mag ride was the chit. why are we removing it???
09-20-2020, 11:22 AM | #9 |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
09-20-2020, 11:23 AM | #10 |
09-20-2020, 02:36 PM | #11 |
The reason I need to delete the Mag Ride is because i'm not smart enough to retrofit it into a 69 Camaro AME chassis....My project is retrofitting everything from a 13 ZL1 into a 69 body. Some things I just can't retrofit like the MAG Ride, so I need to "Fool" the computer that it is still there otherwise it causes issues with drivability and an annoying DIC warning and 85MPH max speed whenever MAG ride is in a fault.
09-20-2020, 07:34 PM | #12 | |
09-21-2020, 03:37 PM | #13 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
I think you can program the computer to higher speed than 85, but you will still get the warning light
Ill have to check my hpt file and get back to you |
09-24-2020, 10:41 AM | #14 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Resistors are color coded. If you can find a way to see what's in the factory wiring you can find the resistor values. Lots of information on resistor color codes out there.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
