#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
BeckyD @ James Martin Chevy
Old 04-07-2020, 03:16 PM   #1
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Illuminated Door Sill Plate Wiring Harness - Now made own harness
I’ve bought a pair of the uplevel illuminated door sill plates and just realized the OEM kit includes a harness with the sill plates. Was wondering if anyone knew either the part number for the harness or another way to wire up the sill plates?
They are the OEM sill plates with the connectors but no harness.
I see the part number for the sill plates are 84127636 and/or 84127637 but can’t find the harness by itself
Bumbleboy92 is offline   Reply With Quote
Old 04-07-2020, 04:30 PM   #2
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
Check this thread
https://www.camaro6.com/forums/showt...nterior+lights
I think you can tap in here, but if you can build youself a simple harness you can save a few bucks.
17rsvert is offline   Reply With Quote
Old 04-08-2020, 03:19 PM   #3
Bumbleboy92
Long hauler
Originally Posted by 17rsvert View Post
Check this thread
Thanks for that! I looked at the pics the guy I bought them from sent me and I realize it’s just two wires from each sill. Hopefully it’s as easy as I’m thinking, gonna get some wire and wait for them to arrive and try out before I install
Old 04-08-2020, 05:39 PM   #4
17rsvert
17rsvert's Avatar
I added colored footwell courtesy lights. You can check it out here https://www.camaro6.com/forums/showthread.php?t=564653
Tapping into the circuit was the easiest part. I'm pretty sure that's the same one you want for the door sills; on when the doors open and timed fade off when closed.
Old 04-10-2020, 10:16 PM   #5
Oramac2016
Oramac2016's Avatar
Drives: 2016 Camaro RS
I used my own wire as well and looked at the harness instructions. On the passenger side is a grounding screw already. And you actually can tap the same place the oem harness does
2016 Summit White 1LT RS, Brembo Brakes, NPP Exhaust,Front Glowtie, Rear Red Glowtie, Adrenaline Red Interior
Oramac2016 is offline   Reply With Quote
Old 04-13-2020, 07:36 PM   #6
Bumbleboy92
Long hauler
I just got my sill plates today and using all the links you guys provided I made what I think is the equivalent of the OEM harness and it works!
(Ignore the flickering, I accidentally kept missing the pos/neg on the 9V)
DIY harness in action
I’m gonna wait for homedepot to open tomorrow to get some heat shrink and probably a bigger ring terminal size to fit the OEM grounding screw as Oramac2016 said
Old 04-13-2020, 08:13 PM   #7
SoulCyphyr71
Drives: 2018 Chevrolet Camaro RS
I ordered the parts and had the dealership install them. Door sills came with the required harness. I'd have thought yours would as well.
SoulCyphyr71 is offline   Reply With Quote
Old 04-13-2020, 08:31 PM   #8
Bumbleboy92
Long hauler
I’m penny pinching 😂
Got the sill plates from a FaceBook member for $80 and realized he didn’t have the harness mid shipping
Old 04-15-2020, 09:21 PM   #9
Bumbleboy92
Long hauler
Two days later and many trips to HomeDepot, I got it!
Thanks for the help everyone!
Old 09-07-2023, 10:09 PM   #10
Mantis-SS
Drives: Camaro SS
Do you have a wiring diagram for this? I'm guessing this is a parallel circuit?
Mantis-SS is offline   Reply With Quote
Old 09-08-2023, 12:02 AM   #11
Bumbleboy92
Long hauler
Not really a diagram but I remember using this install pdf and just copying the wiring myself
https://www.camaro6.com/forums/showthread.php?t=468669
2022 2SS 1LE - Cold Air Inductions Elite Carbon CAI
2016 1LT v6
- Totaled
Happiness: Infinite
door, illuminated, sill plates, wiring harness
