01-04-2017, 12:21 AM | #1 |
Drives: 2013 Black ZL1 "Auto" Join Date: Aug 2014
This is my Setup tell me what you think?
So I have been on the forum a lot but don't really post to much just like to keep it simple. I have been Drag Racing for about 20 years stop around 2005 family became more important, now I am back at it and have had my ZL1 for almost 3 years I do all my own work just not the tuning part.
So with out taking up to much of everyone's time here is what I have: 2013 ZL1 Auto "Bolt Ons Only" Tuned by Rick at Unlimited Performance in Corpus Christi Dual AEM wide bands Metco Setup for pulleys and relocation bracket 2.40 upper 9.55 lower Texas Speed 2in Longtubes w/ header wrap Hi Flow Cats Factory exhaust with bullet mufflers Plugs and wires Ported stock TB "did my self" 160 thermo Solid isolator Rotorfab CAI w/ header wrap My own custom made Chiller Box with Factory pump and twin 1000 pumps Fuel system was only 1000cc injectors on stock pump but got to the point where my fuel pressure would drop to 46psi at full throttle so working on tuning new system where I added the twin pumps to switch to E85 Stock tranny, stall, gears and driveshaft Suspension: Front Removed front sway bar Stock front struts Rear Only thing lacking is coilovers drag shock and lower control arms everything done with BMR and prothane bushings Car is not lowered Auto Power 4 point roll bar Wheels: Old setup Weld RTS 17x4 fronts w/ M&H 28x4.5 Rears Race Star 18x10.5 w/ Hoosier DR 325/45/18 Best time with that setup was 10.42@ 137mph with 1.5 60ft but at San Antonio Raceway prep is not always good so I avg low 1.6 60s New setup for wheels and tires: Still a Weld RTS 17x4 w/ M&H 28x4.5 New rear is Weld RTS 17x10 with Hoosier 28x10 Slick Car weight: 4064 with me and 1/4 tank of fuel. Have not made a pass yet on new wheels and tires or E85 setup My Goal is to be the baddest ZL1 in the Nation with only Bolt Ons and break into the 9s I have done some research trying to find the fastest ZL1 with only bolts one and so far I have come up with almost a 10 flat car, if anybody out there know a different faster car please share a link or info so I know for sure what the current record is. So that is my car in a nut shell |
01-04-2017, 01:33 AM | #2 |
Drives: 2011 2SS Join Date: Mar 2015
Sounds like a badass car brother
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears |
01-04-2017, 01:47 AM | #3 |
Drives: 2019 1SS Crush, 2017 Corolla White Join Date: Dec 2016
That looks badass
Through Christ
01-04-2017, 04:24 AM | #4 |
Drives: 2015 ZL1 Join Date: Jun 2015
Damn how'd you trap 137 mph that's awesome
I'm basically in the same boat as you I'm looking for 4 tenths I ran a 10.425 at 132.84 mph with out the ported blower, fuel system and NW throttle body I haven't made it to the track with my new setup but I'm trying to go next week do you have any dyno numbers from your build I'm currently at 690 RWHP & 679 RWTQ here's my current setup Performance Mods: KRAFTWORKS dyno tune New Era CAI New Era reservoir Vedder performance lid manifold NW 102 mm throttle body Jokerz ported supercharger Jokerz ported snout ARH LT headers ARH X pipe ARH mid section ARH hollow cats OEM NPP exhaust LPE 2.55 upper pulley LPE 9.17 lower pulley Gates K080675HD belt ID 1300 injectors Fore triple pump 160 degree thermostat NGK plugs E85 sensor AFCO HX with fans SJM line lock Elite catch can Roto-Fab w/w relocate suspension Mods: BMR 1 inch drop springs BMR trailing arms BMR outer trailing arm bushing BMR tow rods BMR upper control arm bushings BMR diff bushings BMR extreme rear sway bar BMR front sway bar BMR sway bar links BMR camber bolts |
01-04-2017, 07:04 AM | #5 | |
2013 ZL1 CRT M6
__________________________________________________ ____________________________________ Current Mods: Rotofab CAI, Big Gulp, and Res. ATI Superdamper and 10" Lower, DSX FF Sensor, DSX Aux Fuel Pump, ID850s, Kooks 1 7/8" Headers, Forced Induction Interchiller, McLeod RTX Twin disk. DSX Tuned. Running on 20" MT ET Street SS on stock wheels for the strip. Best 1/4 mile to date:10.81 @130.43 mph w/ 1.61 60' Just added: Jokerz Stage II blower port and FI Interchillers blower lid spacer. |
01-04-2017, 08:42 AM | #6 | |
As for the MPH not sure, this thing has always had a good mph. At first I was thinking the track was messed up but I have gone to a different track and still mph the same. I will be back at the track on the 14th of this month to finish up the tuning and try out the new setup. I will post how it goes. Good luck at the track |
01-04-2017, 09:15 AM | #7 | |
As for boost I am at 17psi it is the original supercharger that came on the car I replaced the isolator instead of taking it in for the recall. |
01-04-2017, 11:44 AM | #8 |
Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
137mph says 10.0's if it would have hooked up, the extra power/torque from E85 will put you into the 9's with traction, I see you getting there with bolt on.
01-04-2017, 05:01 PM | #9 |
Drives: 2010 2SS/RS L99 IBM silver stipes Join Date: Dec 2015
Still stock stall?
2010 Imperial Blue w/ Silver stripes 2SS/RS L99
Mods = Not enough.... |
01-04-2017, 06:28 PM | #10 |
01-05-2017, 03:27 AM | #11 |
Drives: 2014 M6 ZL1 Join Date: Jan 2012
Awesome MPH and setup. What is your best 60' with and without the front sway bar off? The 60 foot may be where you will find your 9 sec slip. MPH is there. 15" wheel setup out back in -DA should get you there.
Sweet ZL1 Man.
15' Ashen Gray Metallic Z/28
14' Crystal Red Tintcoat ZL1 6M, 9.62 at 150.75 MPH 12' Opulent Blue Metallic CTS-V Sedan, 10.690 at 129.60 MPH - SOLD 06' LeMans Blue Metallic Z06, 11.726 at 127.80 MPH Motor - SOLD. 96' Impala SS LTx, 11.397 at 118.10 MPH Motor, 1st stage 10.526 at 127.46 MPH |
01-05-2017, 06:21 AM | #12 |
Emerald Coast Camaros
Drives: 2010 RS/SS Rally Yellow & 68 SS Join Date: Dec 2012
Yeah you may have a 9.99 in it with the 137mph trap. I'm trapping 10.10 with a 156mph
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135 AS OF 1/31/15 @ 633 RWHP=10.16@135 AS OF 1/29/16 @ 633 RWHP=10.10@136 TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF |
01-05-2017, 09:00 AM | #13 | |
Best with out it is 1.50 on drag radials and good track prep avg was low 1.6s |
01-05-2017, 09:06 AM | #14 | |
Knock on wood we will see. |
