01-23-2019, 07:33 AM | #1 |
Drives: '14 BRM 1LE 2SS/RS Join Date: Nov 2017
Which port for LSA bypass valve?
Apparently this is what ADM recommends (see pic) however mine came with it connected the top port and the lower port is blocked off. Which is correct and why? Or does it even matter?
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC |
01-23-2019, 09:55 AM | #2 |
'It's an experiment'
Just the one port with vacuum is needed.
Either will do but, I use the lower: The tube port on the bottom of the valve is blocked off as it’s not used... The plastic tool sets up the correct setting for plunger length... -Don
747 RWHP 794 RWTQ
01-23-2019, 12:01 PM | #3 |
Cool, thanks Don! Yea I need to get one of those tools, LPE carries them right?
01-23-2019, 12:05 PM | #4 |
Yep.. worth having...
-Don
747 RWHP 794 RWTQ
