11-28-2022, 07:26 AM | #1 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
Drive shaft safety loops, What options are out there?
Looking to add a safety loop when I finally get around to installing my Aluminum shaft. What options are out there and which do you guys like? Any clearance or installation issues to watch for? Thanks
14 SS 6 SP. Do I need the extensions? https://www.ebay.com/itm/30463886602...gaAtjEEALw_wcB https://www.ebay.com/itm/38522590986...EaAq3oEALw_wcB
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
11-28-2022, 08:12 AM | #2 |
Drives: 2015 2ss/rs Join Date: Aug 2021
If you are running a stock drive shaft then you won’t need the driveshaft loop extension. I got a metro loop with a after market driveshaft on my m6 with a sonnax flange and it needs the loop extension.
11-28-2022, 09:00 AM | #3 |
I am running a Gulf Coast Aluminum DS, They don't use the same adapters as say DSS and so on. I am assuming if I got the adapters even if I didn't need it should hurt? I rather be prepared then not.
Is Metco the only choice these days?
11-28-2022, 12:01 PM | #4 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
I have that same Metco WITH the extension for my TR6060 and DSS driveshaft. Pretty easy to install and no fitment issues.
> 2021 Camaro ZL1 1LE A10 - power upgrades in the initial design phase > > Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily |
11-28-2022, 12:38 PM | #5 |
Metco with extension here. I tried it without the extension and it wouldn’t be enough to get past the slip joint.
GPI 416 w/Custom GPI Cam, GPI Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
11-29-2022, 06:29 AM | #6 |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
As stated in my build thread where we spoke to eachother. I run the Metco with the driveshaft extension. It's a nice piece. Only takes a few minutes to install. The BMR unit looks really nice, but it requires you to remove the transmission crossmember and drill holes in it for installation. Here is some pictures for reference of my Metco installed. All I have on my phone at the moment.
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 2011 Camaro 2SSRS - Sold No longer a 5th gen owner, but still an enthusiast. Ask me about my Front crash bars! |
11-29-2022, 06:38 AM | #7 |
Yeah I would rather not drill, The Gulfcoast DS doesn't have the adapters like the DSS and others so I am not sure if I need the Extension which I see was $14.99 and now is around $60.
I figured I would ask and see if there are others out there but it appears that Metco and BMR are the choices left. The Metco seems well made and appears to fit well so I'll probably go that way.
11-29-2022, 11:30 AM | #8 |
Drives: 2012 SS Join Date: Dec 2021
I have an auto but I have a UPR...no drilling, bolt on all the way
2012 Camaro SS
11-29-2022, 12:40 PM | #9 |
Joe - Here is a pic of mine with the Gulf Coast DS -
Roy
11-29-2022, 12:54 PM | #10 |
Thanks I am assuming the 6SP would be about the same, I'll order extension when I order.
12-02-2022, 09:36 AM | #11 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
I have the Metco, but with the stock driveshaft. Nice item and easy install.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
12-02-2022, 11:43 PM | #12 |
Drives: 2010 1SS LS3 Join Date: Aug 2019
BMR here. Made my own extension with the DSS shaft and didn’t need it with the ZL1 stock shaft.
2010 CGM 1SS
408/4L80E/ZL1 Vortech V-13 94C |
12-03-2022, 08:58 AM | #13 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Same here.
2010 SS - Kind of an On3 kit, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
12-21-2022, 03:32 PM | #14 |
I ordered the Metco with the extension, No Idea wheni'll install it but when I get to the DS I'll get it in.
