#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 02-04-2024, 04:25 AM   #1
ukester
Drives: 2016 z06
2023 trunk not opening
it does this from time to time where i can hear the latch but it does not pop open and it stays closed-i see where the etr may be the problem has anyone else had this problem and what is the fix?
TIA
Mark
ukester is offline   Reply With Quote
Old 02-04-2024, 06:25 AM   #2
OCDRob
Drives: 2023 Chevy Camaro ZL1
I had the same problem. In my case it was because I didnt open the trunk very often and the weather seal around the trunk opening was sticking to the trunk lid. I cleaned the seal and the area on the trunk lid it makes contact with and applied a ceramic detail spray to the same areas and no problems since. My car is also a 2023.
OCDRob is offline   Reply With Quote
Old 02-04-2024, 06:29 AM   #3
Mid_Life_Crisis
Mid_Life_Crisis's Avatar
Drives: 2023 Chevy Camaro 2LT V6 6MT
My 2023 has done this a few times. I hear the release but trunk does not open. I tried lifting it but couldn’t. Waited a min and hit the button again and it pops up. Odd.
2023 Camaro 2LT V6 6MT Vivid Orange Metallic
Mid_Life_Crisis is offline   Reply With Quote
Old 02-04-2024, 07:33 AM   #4
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
The "poppers" may need a little adjustment and/or the latch might be binding a bit. When the trunk won't open, people tend to do two things: first, push down on it and simultaneously press the button until it opens, then adjust the poppers slightly; and second, lubricate the latch with lithium grease. See these threads below.
https://www.camaro6.com/forums/showthread.php?t=539602
https://www.camaro6.com/forums/showthread.php?t=544455
https://www.camaro6.com/forums/showthread.php?t=471732
735 rwhp | 665 rwtq
Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods
JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune
1100 - 1/30/18 | 2000 - 1/31/18
3000 - 2/06/18 TPW 2/26/18
3400 - 2/19/18 | 3800 - 2/26/18
4300 - 2/27/18 | 4B00 - 3/01/18
4200 - 3/05/18 | 4800 - 3/14/18
5000 - 3/16/18 | 6000 - 3/19/18
arpad_m is offline   Reply With Quote
Old 02-04-2024, 07:52 AM   #5
DangerZL1
Drives: 2023 Black ZL1 Auto
I had the same problem with my 2023. I tried lubing the weatherstripping with gummi pledge and it didn’t help. I greased the inside of the latch striker area and it hasn’t stuck shut since.
DangerZL1 is offline   Reply With Quote
Old 02-04-2024, 08:15 AM   #6
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
My 2017 does that every once in a while when I use the trunk release above the license plate. I hardly ever use the the button on the door panel.
ZL1 Coupe, PDR, Exposed carbon fiber hood insert, My Link with Nav, M6 6 speed and Silver Ice Metallic. Mods done: ceramic window tint, GM Accessories Camaro floor mats and Roto-Fab CAI.
LT4Greg is offline   Reply With Quote
Old 02-04-2024, 08:49 AM   #7
JSH
JSH's Avatar
Drives: '20 ZLE
TIA
Mark
Low battery was the cause when this happened
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
JSH is offline   Reply With Quote
Old 02-04-2024, 11:14 AM   #8
Nataphen
Drives: None
A squirt of lithium grease fixed mine. Also 2023.
Nataphen is offline   Reply With Quote
Old 02-04-2024, 12:27 PM   #9
LeonardS
Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS
I believe there was a recent repair procedure released by GM. It was for the 23 and 24 models. It had to do with the emergency release in the trunk.
24 2SS 1LE, Riptide Blue, A10, PDR. Picked up 11/5/23, 560 miles.
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles.
99 SS Vert, Hugger Orange, A4, 806 miles
94 Z28, Black, M6, 595 miles
92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com
69 Z28, Dusk Blue, M4
29 Ford Business Coupe
28 Ford Pickup
24 GMC Denali 2500HD CCSB 4x4
22 Jeep Grand Cherokee
13 Ford F150 Crew Cab 4x4
LeonardS is offline   Reply With Quote
Old 02-04-2024, 06:18 PM   #10
Buellrider
Buellrider's Avatar
Drives: 2023 1SS 1LE
My 23 also does this and will try the lithium grease.
Buellrider is offline   Reply With Quote
Old 02-04-2024, 07:30 PM   #11
JimGnitecki
Drives: Chevrolet Camaro LT1
Yes, there IS a current recall on this. The emrgency release is not properly seated in position and needs to be adjusted.
Jim G
JimGnitecki is offline   Reply With Quote
Old 02-05-2024, 11:02 AM   #12
Bangkok_ZL1
ZL1 Believer
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
TIA
Mark
my 19 does this and it's because it's shut all the way, but it's not.... When this happens, I just push down on the trunk to lock it again and it pops right up the next time. It's weird. But since I'm in Thailand, I'm not spending time on this until all else is done with my project.
Bangkok_ZL1 is offline   Reply With Quote
