11-18-2023, 07:33 AM | #1 |
Drives: Camaro ZL1 Join Date: Jul 2022
Brembo Brake Rubbing on Tire Counterweights
So I got some Forgestar D5 17x10 and Mickey Thompson street r 305/45/17s. The counterweights the shop installed seems to rub on the brembo brakes and was wondering if I can bend the part that's rubbing. Saw a video of a guy reviewing a different rim, think they were 17x11s, and he said he got those sizes cause he didn't want to bend the brakes like other people. I didnt know if this is what he was talking about. I'm gonna take it back to the shop today and see if they can move them. I read forums saying these rims and tires fits stock Zl1 setups so maybe the counterweight are just put in a bad spot.
11-18-2023, 08:16 AM | #2 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Pretty sure you can ask a shop to balance the tires so that the weights are on the other side and explain that the weights are running against the caliper.
11-18-2023, 12:11 PM | #3 | |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
I ended up having to run some small hub centric spacers to make mine work (and I don’t even have wheel weights lol).
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
11-18-2023, 01:40 PM | #4 |
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE Join Date: Feb 2020
Scrape those weights off before they wear a hole in your calipers hard piped brake line.
11-18-2023, 02:54 PM | #5 |
Drives: 2023 Camaro Convertible ZL1 A10 Join Date: Mar 2023
I use this in all my motorcycles (Way better then weights) and have used it in a couple cars that had balancing issues. maybe look into it if the weights continue to be a problem.
https://www.ride-on.com/us/home |
11-19-2023, 06:51 AM | #6 |
Drives: '21 ZLE A10 Join Date: May 2012
get your shop to shift the weights away from that exact spot where contact will be made...not a difficult task for any tire shop
11-19-2023, 10:04 AM | #7 |
Thanks, everyone. I was able to just get the shop to move the weights. It seems to be good now.
