08-24-2020, 08:27 PM | #1 |
Drives: 2013 1SS BlueRay Metallic Join Date: Nov 2018
Please help getting me lined up
I'm not all that handy. And I took my bumper off to install the heritage grille and new side markers. After getting everything back together the fr8nt drover side doesn't seem to really line up well. Is this something simple I can try or is it back off with the bumper to try again?
08-24-2020, 09:57 PM | #2 |
Drives: 2011 Camaro 2LT Join Date: Oct 2018
Did you get all of those screws inside the fender liner back in correctly? Including the one that has a bolt head facing the engine and threads facing out away from the car? Also, did the bolt behind the turn signal light go back in right? Either way, the tabs can break and could cause a misalignment. Especially that bolt behind the turn signal. It should be an easy fix. You just need to figure out if you left a bolt out or have one not properly lined up. Good luck, you can fix it!
08-24-2020, 10:04 PM | #3 | |
Hey thanks alot. I had posted on the Camaro reddit aswell. Got the same reply pretty much. Thanks for the tips and confidence boosts. I think I can work with this. I just prefer to never take the number off again. Or mainly starting over after I've "finished" again tyvm |
09-07-2020, 01:35 PM | #4 |
Idk if the pics really do justice. But all is well now. Ty so much man. There's just minimal noticeable damage from me being forceful before.
09-07-2020, 11:41 PM | #5 |
Looks good!
