03-30-2020, 06:43 PM | #15 | |
Drives: 2012 Camaro SS Join Date: Dec 2019
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
03-30-2020, 06:45 PM | #16 |
Yeah I wish the 2010's did that.
03-30-2020, 08:10 PM | #17 |
Drives: 2015 Camaro 2SS Green Flash Edition Join Date: Dec 2015
While in S (sport mode), use the paddle to downshift (this locks you into manual shift mode), then immediate slip the shifter forward into D (auto mode) to handle the shifting from there. If you want you can then pull the shifter back into S mode for more manual shifting. Practice frequently to build muscle memory.
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo GPI VVT SS1 cam and CNC ported heads milled .30 BTR .660 springs, Straub solid bushing trunions GPI rod-mod intake with I-M heat sheild Circle D 258mm Pro single disc 3700 rpm stall converter 169F thermostat & manual fan switch Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft |
03-30-2020, 08:25 PM | #18 |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
Dont know what the hell your talking about bud ?
Converters have a lock and unlock , think of its as lock = 1 to 1 for power transfer "it is not one to one just best way i can explane it" , unlock lets the converter slip to drop the rpms while staying in the same gear.... not a good thing plus builds excessive heat that hurts the hydraulic system
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
03-30-2020, 08:35 PM | #19 | |
Nothing idiotic about asking a honest question, if you have ever hit the O/D off or tow/haul button in any auto transmission car or truck you have locked it in
03-30-2020, 08:41 PM | #20 |
Its not going to change the world or give you more power , but it will ensure you get much better chance getting the "hit" on the roll. And all us real street guys know the hit can be the difference between getting gapped or gapping on a roll
03-31-2020, 05:50 PM | #21 |
Drives: 2014 Chevy Camaro SS Join Date: Sep 2019
03-31-2020, 10:57 PM | #22 |
Ponies are for girls
My 2015 allows me to shift anytime with the paddle without going to sport mode on the shifter. If i don't change gears after a few seconds, it will default back to auto shifting. But you don't have to put it in Sport mode to paddle shift.
H&R 1.8/1.7” drop, Overkill 80mm + intake ported by AFS, 1" insulator MACE, Accel Super Coils, THR cai, JET MAF sensor, Hurst shifter handle, GPP strut tower brace, CI ice cube tray hood vents (functional) @SemperFiCamaro
