06-04-2020, 04:14 PM | #1 |
Drives: 2010 CGM Camaro SS Join Date: Dec 2016
Driver side rear axle OEM replacement-Discontinued
So, i need a left rear axle. Thought it was the axle click washer replacement, but the shop is telling me it is the out CV joint binding.
I can't find an OEM one anywhere as GM discontinued. Any idea's for an OEM equivalent to pair with the stock passenger side? |
06-04-2020, 04:37 PM | #2 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Rockauto has left ones by acdelco.
06-04-2020, 08:45 PM | #3 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
ebay...
Good luck! PEACE
06-05-2020, 08:49 AM | #4 |
I need one asap. Car is on the lift. Even a used one from a local yard.
06-05-2020, 09:07 AM | #5 |
advance and oreilly both have listings for driver side.
06-08-2020, 01:34 PM | #6 |
I got this from parts geek. Can I run this on the driverside rear with the OEM passenger side?
Anyone familiar with Surtrack brand axles? |
07-10-2020, 11:05 PM | #7 |
Driver side and passenger side are different. They are not interchangeable
07-10-2020, 11:16 PM | #8 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
I have both sides but shipping would be very expensive.
07-10-2020, 11:57 PM | #9 |
I have both sides also, shipping would be from Knoxville TN. Won't split them up.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
07-13-2020, 12:26 PM | #10 |
used the above Surtrack driverside. so far so good. I have been beating on it too with my new 3.91's.
07-15-2020, 12:03 PM | #11 |
Drives: Camaro Join Date: Sep 2012
A paif for sale right in this part of forum for sale 2 spots above you for $150
