07-14-2020, 01:30 PM | #1 |
Drives: 2009 Corvette ZR1 Join Date: Aug 2012
Replacement rear window antenna
I'm in the final phase of a drastic restomod on a 70 Chevelle where I'm merging a 2014 SS into it. See link below.
The rear antenna was built into the rear window and the Chevelle window doesn't support that antenna, so I need to come up with another antenna idea. A search did not help. TIA, Nick
Here's a link to my 70 Chevelle build thread:
https://www.chevelles.com/forums/12-...aro-donor.html |
07-16-2020, 07:56 AM | #2 |
Drives: 2013 2SS/RS/1LE Join Date: Apr 2010
The factory fender antenna will work. Or any antenna for that matter. I don't know exactly what you are looking for.
07-16-2020, 09:16 AM | #3 |
I'm confident that a cosmetically suitable interior antenna placed critically under the rear window (read that as on top of the package tray) will work.
The problem is that the coax cable feed to the radio has a Fakra Z female connector. Making the transition from the male DIN connector found on most all aftermarket antennas is where I'm running into trouble. Thanks for that input Jim, Nick
Thread Tools | |
