11-08-2017, 04:42 PM | #1 |
More then meets the eye!
can i start my car
I just finished installing a cam and whipple supercharger. Can I start the car to check for leaks? I wont be driving the car till I get my tune. thanks for any advice.
Jon
2010 2SS/RS, M6, OBX 7/8" l/t headers, with high flow cats, MBRP full 3" exhaust, Whipple supercharger, 3.875 pulley, ID-1050X 1260CC injectors, JRE rough idle street blower cam kit, ZL1 fp, ZL1 fpcm, ZR1 3 bar map sensor, cold air intake, Richman 4.10 gears, BMR toe rods, trailing arms, f/r sway bars, f/r sway bar end links, BMR end link brackets, full BMR poly bushing including solid rear cradle bushings, BMR frame connectors and tunnel brace, f/r Hurst swaybar bushing brackets, Fluidamper, MGR shifter, and tune by Jannetty Racing.
11-08-2017, 05:16 PM | #2 |
'It's an experiment'
I would not as you probably installed injectors too. Get a base tune first and avoid possible overload of fuel etc.
Best to be safe When you make a lot of changes like that .. DynoSteve, Jannetty, Rhino79 from GPI are good resources to start with. There are many others but these folks do remotes tunes often... -Don
747 RWHP 794 RWTQ
11-08-2017, 05:30 PM | #3 |
Drives: 2010 SS Camaro Join Date: Oct 2008
Agreed resist the urge, as you may cause damage to internals without proper tuning. Believe me it will be worth the wait. A base tune is needed by a reputable tuner to ensure everything will be ok.
11-08-2017, 05:41 PM | #4 |
Thanks, that's what I needed to hear.
11-08-2017, 07:52 PM | #5 |
Drives: Silver 2010 SS Camaro Join Date: Jul 2009
You're going to love those mods.
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq |
11-08-2017, 08:10 PM | #6 |
Drives: 2010 Camaro SS Join Date: Dec 2006
yep Get the right base tune in there. What kind of a tuner do you have? Do you plan to tune yourself?
11-08-2017, 08:32 PM | #7 |
I have a SCT tuner from Jannetty, he's going to write my tune. I also have a HP Tuner MPVI Pro Would like to learn how to tune.
11-08-2017, 08:56 PM | #8 |
i tune myself with HP Tuners Pro. Hugely rewarding and fun thing to learn how to do. Would encourage you to do this. Lots of help and learning over at the HP Tuners forum.
Jannetty can certainly help you out too. |
11-09-2017, 01:00 AM | #9 |
Thanks, I've ben looking at HP Tuners site..
