Old 05-31-2018, 09:23 AM   #1
Yellow Bullet
Yellow Bullet's Avatar
Drives: 2017 Chevy Sonic RS 1.4T
What Long Tube Headers?
For a 2015 LS3 with optional npp, what Long tubes should I get with Hi-Flow Cats?
2015 Camaro RS/SS SIM LS3- Sold
2017 Sonic Mosaic Black RS 1.4T
Yellow Bullet is offline   Reply With Quote
Old 05-31-2018, 09:34 AM   #2
UBB
UBB's Avatar
Drives: 2018 ZL1
I have ARH with my NPP and it sounds really good
UBB is offline   Reply With Quote
Old 05-31-2018, 11:58 AM   #3
J Rod
J Rod's Avatar
Drives: '14 BRM 1LE 2SS/RS
This is what you need, $1179 after applying 10% off code.
https://www.rdpstore.com/p-6524-stai...stom-tune.aspx
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC
J Rod is offline   Reply With Quote
Old 05-31-2018, 01:00 PM   #4
Bo White
Bo White's Avatar
TSP
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 05-31-2018, 01:21 PM   #5
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
I like my SW 2inch LTs. 100% USA made.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 05-31-2018, 01:43 PM   #6
xc_SS/RS
Drives: 2010 Camaro SS/RS
whatever you can afford or are comfortable spending money on
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 05-31-2018, 02:34 PM   #7
LsxDoctor
15 Year LS1Tech Member
LsxDoctor's Avatar
Drives: 2010 ss 391ci LS3
I have some cheap pacesetter 17/8" I got for about $350new from Summit over a year ago. Easy to install, work great and well worth the price. They don't look too great now that the temp paint burned off but if looks are that much of an issue you can always dish out a few extra bucks for their coated headers.
LsxDoctor is offline   Reply With Quote
Old 05-31-2018, 02:57 PM   #8
Livernois Motorsports
Livernois Motorsports's Avatar
Drives: 2010 Camaro 454 LSX (SOLD)
If you want them to fit properly and last where you will never have to worry about corrosion, you'll want to get a high quality system like Stainless Works, Kooks or American Racing. If you are not planning to add boost, 1 7/8 will be ideal.
We can get you pricing on any of these if you'd like.
Livernois Motorsports is offline   Reply With Quote
Old 05-31-2018, 03:57 PM   #9
Punisher_ATX
Drives: 2010 SS
For the money TSP is nearly impossible to beat. Ive installed about 4-5 sets and have the process down to 2 hours without a lift.
$520+ shipping for headers connection pipes gaskets and o2 extensions.
Punisher_ATX is offline   Reply With Quote
Old 05-31-2018, 08:59 PM   #10
Slvr-camaro15
Slvr-camaro15's Avatar
Drives: 2017 zl1 ,2010 SS /RS L99
Speed engineering ?
What about speed engineering ? Any thoughts ?
2017 zl1 - rotofab CAI , PDR , Nav .
2010 camaro SS - Procharger D1 sc (Stage 2 with upgraded intercooler)+ whole lot of other goodies ( too many to list )
Slvr-camaro15 is offline   Reply With Quote
Old 06-01-2018, 04:15 AM   #11
Ashen L99
Ashen L99's Avatar
Drives: Ashen grey, 1SS, L99
The OP said “with cats.” Speed engineering headers are catless unless you get cats from somewhere else.
But yes, they are a budget friendly header that will perform just as good as any other brand. After all, we are talking about bent metal tubing...
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
Ashen L99 is offline   Reply With Quote
