11-23-2014, 07:43 PM | #1 |
Drives: '13 2LT/RS Twin Turbo Join Date: Aug 2012
Resonated X-pipe for twin turbo setup?
How will the magnaflow resonated x-pipe work in a twin turbo exhaust setup? Just wondering since the resonated xpipe doesn't direct the flow as well as a true xpipe or hpipe. Its more just like a big empty muffler with two in and two out. Seems like it might disrupt flow some but I don't know, it probably wont matter since ill only be around 400-450whp.
My setup now is the resonated xpipe to factory resonators, then into 2.5" muffler delete and quad tips. Would it help to get rid of the 2.25" pipe and factory resonators between the xpipe and muffler delete to make the whole system 2.5"? What do you guys think? |
11-23-2014, 07:46 PM | #2 | |
Hide! My wife's coming!
Drives: 2013 Chevrolet Camaro ZL1 Join Date: Jun 2011
I have a magnaflow resonated X pipe on my supercharged ZL1. No issues with flow. Pushing 630RWHP. I installed it mainly to tone down the headers to NPP exhaust.
2013 Camaro ZL1 Convertible CRT - 630 RWHP / 620 RWTQ - ADM Performance Built/Tuned - ZL-700 Package - LS9 CAM - Lingenfelter CNC Ported Heads - Stainless Power Headers
11-23-2014, 11:24 PM | #3 |
Should work just fine for me then, thanks.
11-23-2014, 11:26 PM | #4 |
Don't Sleep on My V6
I have the Magnaflow Xpipe, cat delete, resonator delete, 2.5" pipes and MRT V1 exhaust pushing 501rwhp and no issues at all. Car actually spools faster as it is known to recycle the exhaust gas energy producing more power. But also with a turbo you have to be careful with over spooling the turbos with a too unrestricted exhaust set up.
11-24-2014, 01:51 AM | #5 | |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
11-24-2014, 12:12 PM | #6 | |
11-24-2014, 01:23 PM | #7 |
Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
If you remove too muchl back pressure you can overspool smaller turbos. I'm not sure if going 2.5 all the way back is going to be a problem with the IPS kit or not. I know I've seen problems when people have gone to big diameter exhaust and even cutouts behind the turbos. If Fabbrage says 2.5 in. is fine I think you'll be okay.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
11-24-2014, 02:12 PM | #8 |
Well if going 2.5" all the way won't help me over 2.25" then I will just leave it alone. I was thinking about not enough flow, not too much flow. I've got alot of learning to do about turbos.
11-24-2014, 04:27 PM | #9 | |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
11-26-2014, 11:48 AM | #10 | |
Sent from my HTC One_M8 using Tapatalk
11-26-2014, 01:31 PM | #11 | |
11-26-2014, 07:04 PM | #12 | ||||
Current set up, just cruising around after install in March. And other older videos:
11-27-2014, 07:54 AM | #13 |
Yeah that seems to sound good, it's always hard to tell from videos. The resonated xpipe has had the best sound so far for me, that and the corsa. I had corsa to start with I should have stuck with that.
