01-21-2012, 06:23 AM | #1 |
Drives: 2011 Camaro Victory Red 2SS/RS Join Date: Jun 2011
CAI: difference in 1/4
Once again the search button fails me with irrelevant information
I was wondering who has only a CAI and been on the 1/4 and if you have stock drag times and drag times with the CAI. Is there even a difference? What is your coolant temperature reading on your DIC? I am getting about 200 degrees at idle. Is this normal?
2011 LS3 Bone Stock 1/4 - 12.841 @110.69
LS3 + CAI (no tune) 1/8 - 8.27 @ 89 |
01-21-2012, 07:30 AM | #2 |
Noone?
01-21-2012, 07:48 AM | #3 |
Only drives on Sundays
Drives: '16 2SS A8 NPP MRC NGray Join Date: Feb 2011
Check my Build Journal. I did mine with a tranny tune at the same time and gained a 0.296 ET and 1.25 MPH in the 1/4.
200* is not terrible. I normally race at 180* because I have an electric water pump. But in the 190*'s is about normal for a stock car. If it's 210*+, sit and let it cool. Padre |
01-21-2012, 09:15 AM | #4 | |
Ted.
www.jannettyracing.com
01-21-2012, 09:45 AM | #5 |
Thanks for the info guys! And yes I have the cold air intake already on but it is still reading 200, but if that's normal that's good
01-21-2012, 09:57 AM | #6 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
CAI will help bring cooler air into your engine (making more HP and usually
.2 tenth or so improvement in the 1/4 mile). But that doesn't mean your engine can't run hot if your driving aggressively or in stop and go traffic, especially in warmer weather. A CAI really isn't designed to keep your engine cool. Its just bringing cooler air into the engines intake producing more HP. Your engine can still run hot or over heat if its not running properly or driven very aggressively (hot lapping it at the track for example). Some guys have their engine fan set to come on at a lower temp and that can help cool the engine. Also make sure you have proper coolant levels. |
01-21-2012, 10:34 AM | #7 | |
Drives: '11 Camaro 2SS/RS LS3 Join Date: Jan 2012
01-21-2012, 11:34 AM | #8 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
I dont know about LS3's but Ls1's and both being aluminum like 190-205 degrees water temp for best power on N/A cars.Over that no good and under same thing. They like a bit of heat. now colder air is a different thing, colder the better but not the same as colder engine so dont confuse the two.
01-21-2012, 11:45 AM | #9 |
Quit being a pu$$y
You need a 160 degree thermostat. Most noobs think this means your car will run at 160 degrees, which is obviously too cold, but it only means that the thermostat begins to open at 160 degrees. My car runs at 180 degrees (plus or minus 2 degrees) at all times and that is GREAT for making the most power!
01-23-2012, 07:11 AM | #10 |
Engine Temp needs to be above 185 degrees for Clearances to be correct and for Oil Additives to be active.
Hence the 186 degree Thermostat. Thermostats set the lowest temp the engine can run and fans and radiator set the upper limits of Temp. Ted.
01-24-2012, 01:56 PM | #11 |
Drives: 2021 1LE Join Date: Jul 2011
With your tune what if any adjustments are made to the fans?
01-24-2012, 03:06 PM | #12 |
I make the fans more aggressive for cooling to keep temps at 90C
Thread Tools | |
Similar Threads | ||||
Black CAI Inc. Intakes IN STOCK and ready to ship at Apex Motorsports! | Apex Motorsports | V8 Bolt-Ons & Tunes | 323 | 08-09-2012 05:21 PM |
V6 CAI Inc Intake System At Apex Motorsports! Reserve Yours Today!!! | Apex Motorsports | V6 Bolt-Ons & Tunes | 17 | 09-28-2010 11:27 AM |
V6 Black CAI Inc intake Systems! Now Accepting Pre-Orders at Apex Motorsports!!! | Apex Motorsports | V6 Bolt-Ons & Tunes | 10 | 08-20-2010 07:53 AM |
Watched a 2011 5.0 GT at the track. | JJ#48Racing | Chevy Camaro vs... | 143 | 07-21-2010 06:56 PM |
Audible difference after adding CAI | domano 68 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 10 | 07-15-2009 10:26 PM |
