Old 12-16-2019, 08:03 AM   #1
Scotty D
Drives: 2014 1le 1SS CRMT
Which power added should I do ?
Ok so this spring Iím doin a LSA 416 and Iím on the fence on which power adder to go with ?? Itís between doin an AGP twins , and magnason heartbeat or doin a LSA conversation but replacing the 1900 stocker with a Kongís 2650 ?? The Camaro is going to be a nice weather or weekend show/ strip type deal
Any input is greatly appreciated
Thanks guys
Scotty D is offline   Reply With Quote
Old 12-16-2019, 08:14 AM   #2
Omega
Drives: G8
Do you want instant TQ or are you ok with it being applied with a bit of delay? Would you prefer belt maintenance or going over the system for boost/oil leaks? Is adjustability with a boost controller important?
Sent from my Pixel 4 XL using Tapatalk
Omega is offline   Reply With Quote
Old 12-16-2019, 08:22 AM   #3
Scotty D
I don’t mind a little lag !! I love turbos . What I’ve read it’s lot easer to make more boost and turn it up down the road ! I believe?!?! ��*♂️ And everybody has superchargers I like to be different
Old 12-16-2019, 08:35 AM   #4
Omega
Drives: G8
Sounds like you already know what you want!
AGP makes a very nice kit, you won't be disappointed.
Yes, with an electronic boost controller, you can go from mild to wild with a touch of a button... MPH if you prefer.
Old 12-16-2019, 08:39 AM   #5
Scotty D
Lol yea !! but still like to have your guys input .. and opiniona
Thanks for yours bud
Old 12-16-2019, 09:48 AM   #6
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Max effort Max power Turbo. Heartbeat would be cheaper than an LSA and 2650 but you'll have the option to get more power from the 2650. I love my Whipple, I don't like turbos for a street car but that is simply preference they are certainly cool. I think supercharger is the more simple approach. I would do LSA with 2650, my opinion.
Greenhornet2 is offline   Reply With Quote
Old 12-16-2019, 10:07 AM   #7
Scotty D
Ok ok ! I Like where your heads at ! Thanks bud
Old 12-16-2019, 10:18 AM   #8
Juiced1
Drives: 2012 2SS CAMARO 45th
What are your main power goals? Also, is the motor already being built? What compression ratio will it have?
Juiced1 is offline   Reply With Quote
Old 12-16-2019, 11:55 AM   #9
Scotty D
North of 800+ to the wheels
And compression between 9-9.5 !! January it’s getting started
Old 12-16-2019, 02:17 PM   #10
Juiced1
You can really go anyway. Just make sure you decide which one you want before you pick your cam. PM sent
Old 12-16-2019, 02:50 PM   #11
graf101
KING_1LE
graf101's Avatar
Drives: 15' RRM/2SS/1LE
Twins all the way! More potential for growth.
graf101 is offline   Reply With Quote
Old 12-16-2019, 04:05 PM   #12
Scotty D
Thatís what I was thinking to
Old 12-17-2019, 07:36 AM   #13
JANNETTYRACING
JANNETTYRACING's Avatar
Thanks guys
By spring you might see a Magnuson TVS 2650 if the powers at be will get the memo.
We just did an AGP kit on a stock long block LS3 with our cam package, on 11 psi made 740 ish without leaning on it.
I see no reason why this kit on a 416 won't do 850 plus with the right turbo selection.
JMO, For drag racing, if auto trans, I say go turbo.
If manual trans go supercharger because 60 ft is everything.
Ted.
www.jannettyracing.com
Celebrating 35 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 12-17-2019, 08:23 AM   #14
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '11 2SS/RS IBM/BLK M6
D1X on 416 has been simple trouble free on M6 416 Car here. Mainly Street Car and occasional 1/2 Mile. More in it to be found at only 12lbs Boost but fun the way it is.
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416
ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly
SSBUSDRVR is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
