Old 02-19-2020, 03:53 PM   #1
Fassted
Drives: Imperial blue 2010 2ss
17" weld beadlock clear?
17x10 7.2 backspace clear on a 2010 camaro ss that is lowered one inch with trailing arms and toe rods? The tire spins freely in the air with no issue. I'm worried about applying the weight and at launch. Does anyone have a similar setup and have no issues/issues?
Fassted is offline   Reply With Quote
Old 02-19-2020, 04:15 PM   #2
Vegas Bound
Drives: 2013 Sparkly Red One
Clears mine.
Vegas Bound is offline   Reply With Quote
Old 02-21-2020, 04:53 PM   #3
bayarea408
bayarea408's Avatar
Drives: Turbo 10' 2SS RS
i wouldnt do it. weld 17's are intended for oem ride height, BMR sells 2 LCA's that are notched for specifically lowered vehicles. Honestly, it even depends which trailing arm you use as well i have seen those big pfadt trailing arms contact on lowered cars.
You launch with any power and i bet they mangle your wheels. Seen it time and time again.
2010 2SS/RS -Huron Single Turbo Precision 76/75 cea
bayarea408 is offline   Reply With Quote
Old 03-02-2020, 08:52 PM   #4
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '11 2SS/RS IBM/BLK M6
Don’t have Beadlocks Had Welds now have Forgestar 17 inch Lightweight Drag Version F14 with 325 45 17 M&H Racemaster. Car lowered 1 inch Tried Notched had some slight rubbing. Was recommended for clearance and went with BMR Adjustable Arms. No issues since.
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416
ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly
SSBUSDRVR is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
