07-27-2016, 03:28 PM | #1 |
Tr6060 help
Ok so my car is down getting the motor rebuilt.
I need to beef up my trans a bit and help it shift faster. 1-2 gear was always garbage and so was 3-4. What should I put in my trans?
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
07-28-2016, 08:09 AM | #2 |
Drives: 2011 Camaro 2SS Join Date: Sep 2015
4l80/th400 swap? just an idea, they work great with turbos lol
07-28-2016, 08:28 AM | #3 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
Tick performance, rkt performance, rpm transmissions few others do rebuilds on the tr6060. Might want to consider a billet output shaft and bearing also, i broke mine at the track. They wont sell you the billet shaft though you have to send your trans in to get it installed.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
07-29-2016, 04:19 AM | #4 | |
Kinda dumb they won't sell the shaft. I just pulled my trans and it has a lot of side to side play on the input shaft. I'm wanting to replace all bearings, fork pads, and synchronizers. Maybe 2nd and 4th gear if they are damaged. Just don't know who to order parts from.
07-29-2016, 06:01 AM | #5 | |
I.AM.
Drives: 2011 2SS/RS/A6 cammed-n-whippled Join Date: Oct 2008
NY5thgen.com
