Emblempros
Old 11-20-2016, 02:40 PM   #1
robbiegordon
Robert
robbiegordon's Avatar
Drives: 2011 Summit White SS LS3
Engine Bay Wiring Corner Cover
i saw this on someones car and thought it looked kind of cool but wasn't willing to spend 100+ dollars on it. so i got bored today and gave making one a shot.. i think it came out pretty good, for a 5 bucks, since i had most of the materials laying around. but if you had to buy everything you'd probably be in around 20-25 bucks...
i traced out a general/eyeballed measurement on card board for the template and cut it till i was satisfied with the fit..
i traced that onto a small piece of sheet metal (22 gauge) that i got from home depot for 5 bucks.. i made my bend prior to cutting so i would have more leverage. then i cut out my outline with a pair of tin snips and used a dremel to smooth out the rough edges
after that i just primed it and painted it . threw some rubber trim i had bought a while back at autozone for a motorcycle fender i made ..
overall this was pretty easy and i think it came out pretty good. im probably going to end up painting it black or maybe carbon fiber wrapping it at some point instead ... but yah. it was a fun and easy little project for a sunday.
Turbonetics T76 10psi with aem truboost controller, 231/239 115 LSA Comp Cam, adm fpcm, zl1 pump, Tr7ix plugs, 3.91/1LE Gears,Melling Oil pump, custom intake, catless midpipes, powerbond 25% underdrive, PFADT Aluminum subframe bushings, 1.5 inch drop, PFADT sway bars, BMR; sub frame connectors ,Trailing arms, Toe Rods, strut tower brace and rear diff bushings, Hurst short throw shifter and line lock,dyno #s TBD, , tuned by Pat G tuning
robbiegordon is offline   Reply With Quote
Old 11-20-2016, 03:23 PM   #2
robbiegordon
Robert
one more
Old 11-20-2016, 03:56 PM   #3
speedzalot
speedzalot's Avatar
Drives: 2011 Camaro SS
Thanks for sharing, looks good,I'll have to try this whenever it warms up in a few months .
speedzalot is online now   Reply With Quote
Old 11-23-2016, 10:13 AM   #4
Bradley
Gray Eagle
Bradley's Avatar
Drives: 2010 Camaro 2SS/RS IBM, 1994 Camaro
Looks Goods!
Ordered - 14 Aug 2009 Born - 4 Nov 2009 Delivered - 17 Dec 2009
Bradley is offline   Reply With Quote
Old 12-20-2016, 07:14 PM   #5
chuckie669
chuckie669's Avatar
Drives: 2011 ss
Good job. Is it secured or will it bump around driving.
chuckie669 is offline   Reply With Quote
Old 12-21-2016, 09:28 AM   #6
Stewart
Stewart's Avatar
Drives: 2014 Camaro 2SS RS & Ground effects
Originally Posted by robbiegordon View Post
one more
That looks great Robbie, I think it really finishes up your the engine bay nicely. I got mine from a member on here awhile back for around 30.00. I do not remember his name though.
Donít walk in front of me, I may not follow; Donít walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260
Stewart is offline   Reply With Quote
Old 12-21-2016, 10:08 PM   #7
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS 05 Jag S type R
I made one about a year ago out of aluminum and painted it yellow to match the car. Looks good. The one OP built looks good as well. Nice job.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, No Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
Old 12-26-2016, 05:59 AM   #8
robbiegordon
Robert
Thanks everyone, and yah its really snug in there . Doesn't move around at all.
