10-26-2019, 08:39 PM | #1 |
weSS1LEy
Drives: 2015 camaro 2ss/rs/1le Join Date: Sep 2015
Recommend cylinder heads?
Won’t do it for less than 30hp. Looking for increased flow, increased compression and safer valve angle. Anything else I need to consider? AI, AFR, PRC, ...
Rotofab, arh no cats, atak, elite cc, 94 octane tune, Mobil 1, phastek scoop, custom cam 230/243 .621 .604 114+4, related cam kit stuff. 470/435 rwhp/rwtq
10-26-2019, 08:59 PM | #2 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
Have yours ported....
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
10-26-2019, 10:20 PM | #3 |
PRC 260
10-27-2019, 12:15 AM | #4 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Grab some GM CNC ported, or port your own, and mill them. That is the best bang for the buck.
More to come. Last edited by Black_SS10; 10-27-2019 at 12:25 AM. |
10-27-2019, 01:18 AM | #5 |
Drives: 13' 1LE Join Date: Apr 2012
Higher compression will be the real big gains, and power in the mid range I guess. Not much of you're staying same comp ratio.
There's like 2-3 guys in recent threads saying they gained 0hp with ported aftermarket heads. But gained 20-30 in the mid. I'll just freaking go all out on lightly ported stockers/notching/high comp ratio and spin them to the moon till it blows. I think with stock manifold and medium cam it's not much of a gain, except better PTV clearance With higher comp ratio...
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
10-27-2019, 04:13 AM | #6 |
Drives: 2015 SS/RS 1LE Join Date: Dec 2014
What about going smaller ported like the TEA TFS 245's?
10-27-2019, 08:44 AM | #7 |
Drives: 2014 Camaro 2SS Join Date: Feb 2015
MAST or AFR gets my vote if your set on buying them.
10-27-2019, 10:49 AM | #8 |
Drives: 2015 1LE Join Date: Oct 2015
Trick flow from Total Engine Airflow, good head with a good valvejob.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
10-27-2019, 10:52 AM | #9 |
10-27-2019, 12:12 PM | #10 |
weSS1LEy
And sounds like a ported manifold from GPI may be helpful too?
10-27-2019, 06:06 PM | #11 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
Ttshovel in another thread ....closing in on 7's...says his heads are stock. I'm thinking stock is good.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
10-28-2019, 12:44 AM | #12 | |
10-28-2019, 01:17 AM | #13 |
That's what I read, unless I'm crazy. I quoted him. 1 guy* said they gained 30hp/20tq ish in the mid range but 0 up top.
https://www.camaro5.com/forums/showt...=563836&page=2 I'm thinking PRC 260 heads will run away, maybe on extreme setup up top and mid range. Those LS3 are hard to beat up top though. I like the customizable part of the PRC with chambers available down to 62cc!! I'd sure hope I'd gain more than 20-30 over LS3 with top tier like Mast or other 3k$ plus heads
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. Last edited by WHAMMO; 10-28-2019 at 01:34 AM. |
10-28-2019, 09:24 AM | #14 |
I gained 15rwhp off ported stock heads alone with a cam so small I was already running with stock springs.
https://www.camaro5.com/forums/showthread.php?t=445936 I then later on swapped to the BTR 3 cam and then swapped to th400. Wanting more power I swapped over to a set of PRC 260s with 65cc chambers and the TSP F-35 Cam https://www.camaro5.com/forums/showthread.php?t=520120 All the testing was on the same dyno. Dont know what I gained from the cam or heads seperately but bet most of the gain was from the heads. |
