03-03-2019, 09:44 PM | #1 |
Drives: 2010 camaro ss Join Date: Jun 2010
Need a colder plug?
So I have the br7ef gapped at .026, what could be the reason behind this?
03-03-2019, 10:13 PM | #2 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
tune...
03-03-2019, 10:14 PM | #3 |
That was just #6 plug. All others were good
03-03-2019, 10:15 PM | #4 |
that's some major detonation. what fuel and power level are you at
03-03-2019, 10:30 PM | #5 |
Made 843whp . 20 psi. Loaded mustang dyno, th400. I run e85 and meth. Agp tt kit 62/62 turbos. Ljms cam
03-03-2019, 10:38 PM | #6 | |
nice setup. maybe an issue with that #6 injector. id pull them have them flow tested/cleaned.
03-04-2019, 09:45 AM | #7 |
03-04-2019, 09:55 AM | #8 |
Drives: Black 2SS RS w/White Stripes Join Date: Mar 2011
How did the other plugs look?
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods | Installed by Me & Tuned by Pat G |
03-04-2019, 12:55 PM | #9 |
Pretty much all like this. Just normal wear
03-04-2019, 01:27 PM | #10 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Is it just the picture, or is the entire electrode missing?
Looks like you took out that cylinder. The electrode is probably stuck in a ring. Compression test?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
03-04-2019, 01:31 PM | #11 |
And this one covered in white specks...
03-04-2019, 02:19 PM | #12 |
03-04-2019, 02:26 PM | #13 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
I'd be checking that cylinder. use a bore scope or pull the head. that other plug is covered in piston from the looks of it. chances are that hole is dead
03-04-2019, 04:20 PM | #14 |
Drives: it changes Join Date: Nov 2010
Detonation, bad tune, or other fuel supply/tune related problem.
As others have said, very likely the remains of the plug have caused other damage, and good chance that piston is toast too. You may or may not see the damage with a borescope. You may be incredibly lucky and it is just the plug, but that would be very rare. If you believed it was an injector issue, you could have them tested. What injectors are they ? Are they proper units or cheap stuff ? Were they properly flow matched set ? |
