JUICEDMOTORSPORTS
Old 01-13-2013, 12:22 PM   #1
lsxfox
Drives: 2011 1SS
1968 Chevrolet C10, LS1, Air ride
1968 Chevrolet C10 sb step side, LS1/4L60,Air ride
2002 LS1 /4L60 trans.,PS,PB,a/c , tach and gauges . tinted window, air ride.
All original sheet metal …. Cab corners, rockers , floor pans are in excellent condition. There is a little rust under the battery box, but otherwise this truck is super clean. It was restored about 10 years ago. So the paint and interior are a little dated, but decent . The truck also has a Southern Air a/c setup on it. I have the compressor, but needs new lines made up and charged. $14,000
2002 LS1 /4L60 (68k miles)
3200 tci convertor
Thunder racing 224/244 cam
Comp beehive springs
Comp push rods
Alum radiator
Electric fan (computer controlled)
Air ride
2600 lbs bags
3 gal air tank
Air Compressor
Paddle valve controls
Porter Built tubular trailing arm cross member
Porter Built 2” drop blocks in rear
Porter Built bolt in C notch (welded)
Porter Built adj. track bar
Porter Built rear shock reloc.
73-87 Bell tech 3” drop spindles
20x8.5” front 20x10” Boss 338 Wheels
lsxfox is offline   Reply With Quote
