Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Old 06-25-2018, 06:48 PM   #463
IZM 1
Drives: 2011 Mod
IZM 1 is offline   Reply With Quote
Old 06-25-2018, 06:49 PM   #464
IZM 1
Drives: 2011 Mod
Old 06-25-2018, 06:51 PM   #465
IZM 1
Drives: 2011 Mod
Old 06-25-2018, 07:14 PM   #466
2011WhiteSS
2011WhiteSS's Avatar
Drives: 2011 White 2SS
Is the hat on the wrong side of the ring?
2011WhiteSS is offline   Reply With Quote
Old 06-25-2018, 09:18 PM   #467
cdb95z28
cdb95z28's Avatar
Drives: 2022 1SS 1LE A10 BCD WCT+PDR
Those rotors, what is the part #? Are they for a Gen 5 Camaro? Did you check the offset of the new rotors vs your OE ZL1's?
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
cdb95z28 is offline   Reply With Quote
Old 06-26-2018, 11:16 AM   #468
IZM 1
Drives: 2011 Mod
The rotors are for a Gen 5 (2012-2015 ZL1/CTS-V). They are Power Stop rotors, part of they Z26 Street Warrior kit. Kit number K679026, individual rotor p/n: Right AR82176XR and Left AR82175XL.
It is a BB upgrade from the stock SS 4 piston calipers on a modified 2011 SS.
Old 06-26-2018, 11:19 AM   #469
IZM 1
Drives: 2011 Mod
The hat is mounted to the exterior (outer side) of the ring.
Old 06-27-2018, 05:03 PM   #470
IZM 1
Drives: 2011 Mod
The calipers (GM) are p/n: 20982734 and 20982719
Manufacturer p/n: 172-2521 and 172-2522
The backspacing on the new rotor is 1.425"(36.195mm) and old SS rotor (with about 45,000 miles of moderate driving) was 1.210"(30.73mm).
Rotor thickness- new 1.340"(34mm) and old SS rotor 1.278"(32.46mm)
Old 08-18-2019, 06:31 PM   #471
rudiitee96
Dolfie96
rudiitee96's Avatar
Drives: 2014 Camaro 2SS Erebos
amazon list for front brakes
Made a list for the front brake conversion
http://a.co/6ehpcH4
I'm just here to learn things and spend my money
rudiitee96 is offline   Reply With Quote
Old 08-18-2019, 06:45 PM   #472
rudiitee96
Dolfie96
rudiitee96's Avatar
http://a.co/6ehpcH4
all that's missing is the caliper bolts (unless I missed yet another part)
Old 08-21-2019, 09:39 PM   #473
2011WhiteSS
ACDelco 20944531 GM Original Equipment Front Passenger Side Brake Dust Shield https://www.amazon.com/dp/B007Q1BWSA..._r.FxDb4MX9120
ACDelco 20944532 GM Original Equipment Front Brake Dust Shield https://www.amazon.com/dp/B007Q1BXAC..._8aGxDb5BWKYZG
Old 12-06-2020, 06:07 PM   #474
cdb95z28
cdb95z28's Avatar
New option for rotors. Brembo 2 piece, non-GM sourced.
I found this on Rockauto.com.
Brembo now has their own aftermarket 2 piece ZL1 rotors. They look identical to their same 2 piece rotors they supply GM with.
I have purchased them and they have the same vent design, vane count and the same hat and fasteners The finish looks the same.
https://www.rockauto.com/en/catalog/...hub,rotor,1896
BREMBO #09A66513 Left
BREMBO #09A66523 Right
Prices sometimes change on RockAuto, but they are currently about $170 each, compared to the GM sourced Brembos at about $290
It is possible that the cast iron is different, but everything else looks to be the same. As I mentioned, I have purchased a pair . I track my '14 1LE with the 6 piston front brakes and have no reservations with using these on track. They very well could be 100% identical but without the GM price surcharge.
https://www.brembostoreusa.com/produ...rotor/09A66513
https://www.brembostoreusa.com/produ...rotor/09A66523
Old 12-08-2020, 08:35 PM   #475
608RS
608RS's Avatar
Drives: 2015 2ss
Attachment 1052283
interesting, i'm gonna have to dig more into this myself and see if these are pretty much the same thing just minus the OEM markup. i'm going to need a brakejob soon, thanks for sharing this. let me know your findings too.
actually the part numbers are pretty much identical to the ones on Brembo's site vs. RockAuto so i'd say this is legit
2015 Camaro 2ss, NicKey Performance built/tuned
608RS is offline   Reply With Quote
Old 12-09-2020, 08:55 AM   #476
cdb95z28
cdb95z28's Avatar
Picture of the boxes of these Brembo rotors. Rockauto normally does not use the zeros on manufacturer's part #s. I noticed this with Centric part #s also on their website.
