01-13-2015, 05:50 AM | #15 |
Drives: 2014 ZL1 White Convertible Join Date: Aug 2013
I was feeling kind of disappointed when my performance shop told me they had put in bre7 plugs (a colder plug) especially when I had paid 120.00 dollars to buy a set of Plustar plugs for it. Now I guess I am glad to hear a colder plug can be better.
01-13-2015, 12:20 PM | #16 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
Loss of power was the drop in fuel pressure and not the plug itself. That lean condition would have burned any temp rated plug. I'm fairly certain that Lingenfelter upgrades the fuel system and they just don't talk much about it. Good thing you just burned the plugs and not the pistons. Hope you get it worked out. Don't run E85 unless you convert to the dual squash pumps....
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
01-20-2015, 01:45 AM | #17 |
Drives: 2013 ZL1 A6 Camaro, 2015 C7 A6 Z51 Join Date: Apr 2014
Well finally got the car back up and going again. Added a BAP and the fuel pressure is holding nicely at 65 PSI at WOT. Car made 608 RWHP and 590 RWTQ on 91 and made 619 RWHP and 619 RWTQ on 91 (3/4 tank) and 1 can of Torco. Was expecting higher numbers, but the car had made 20 pulls by this time, so those numbers are on a Heat Soaked S/C. Only running 15 degrees of timing right now.
Roto-Fab CAI, Texas Speed Headers, Texas Speed X-Pipe, Texas Speed LS3-B Blower Cam, Metco 9.10" Crank Pulley, Metco 2.5 Upper Pulley, ID 850 Injectors, LPE Ported Throttle Body, Alky Control Methanol kit, E2 Catch Can, 610HP / 608 Torque.
01-20-2015, 08:41 AM | #18 |
I'm always willing to sacrifice 10hp for durability and piece of mind on my tune.
