06-09-2022, 01:29 PM | #1 |
Drives: 2018 Camaro SS 1LE Join Date: Oct 2019
Valvoline 5w40 “European” formula
I noticed through some old threads that a lot of people are running 5w40 valvoline 5w40 for track use. The one I’m seeing is branded as “European” formula”. Is that the one people are referencing?
06-10-2022, 01:49 PM | #2 |
Drives: 17 SW 1LE Join Date: Jun 2017
06-10-2022, 04:30 PM | #3 |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
If you want to stick to GM's specifications to a tee, then unfortunately Mobil1 is about the only option. If you are okay with 5W-40 then Motul has some oils that meet Dexos2. The link posted above will show you all the oil that meets Dexos2.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
06-11-2022, 09:01 PM | #4 |
Drives: '18 1SS 1LE Join Date: Sep 2017
Valvoline had 5w40 that was dexos certified along with the Euro formula, but it was discontinued.
Since then I've been running Amalie 5w40 which is still dexos certified. I believe Havoline makes a 5w40 dexos if you can find it.https://www.carid.com/amalie-oil/eli...motor-oil.html That dexos list is highly optimistic and outdated. Many oils are not available in many markets and others are discontinued like the Valvoline for example.
'18 1SS 1LE Black, PDR
06-12-2022, 06:53 AM | #5 |
Drives: '21 ZLE A10 Join Date: May 2012
this is a good option and it is Dexos 2
06-12-2022, 10:55 AM | #6 |
Ok great. I think i will go with the motul. Thank you all
06-12-2022, 11:51 AM | #7 |
Drives: Where to begin... Join Date: Mar 2017
I plan on running the Motul X-Clean as well. They have multiple different variants of it though. Not sure which is the correct version.
06-12-2022, 01:19 PM | #8 |
Drives: 6th gen Join Date: Aug 2013
The one that says dexos 2
‘22 2SS 1LE M6 Summit White - RF, Flexfuel, LT2 intake, 95mm tb, ATI udp, VT ramair, full 28” dragpack - 11.68@122
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold) |
06-13-2022, 12:14 PM | #9 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
I don't see the point beyond a full synthetic from a major manufacturer of the correct weight. I just havent bought in to this ESP and European Car formula and Dexos whatevers.
06-13-2022, 02:10 PM | #10 |
If you don't track your car then 5W-30 with Dexos1 Gen 2 will work just fine. Just saying.
For people who both DD and track, that's where 0W-40 Dexos2 comes in. Given this is the 1LE section, I think a lot of people do track. For warranty purposes, it helps to stick to the oil specifications.
Current:
06-15-2022, 09:01 AM | #11 | |
06-15-2022, 10:13 AM | #12 |
BLUPRINT_1LE
Drives: 2022 Rapid Blue SS 1LE Join Date: May 2017
I've used 0W-40 ESP European Formula during my oil change and the car is still running good. No issues so far. However I have a 2022 and that's what they require now. My 2016 required what you mentioned but I still put 0W-40 in it back then.
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- |
06-17-2022, 04:37 PM | #13 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
This is probably the best deal on Amalie 5w-40 https://www.amazon.com/Amalie-Elixer.../dp/B01N6X1R9P
24 Audi S3 prem plus, sport package
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
06-30-2022, 02:03 PM | #14 |
Shifts under load
I think this oil crap is a load of bs. Now they have "Super Car" Mobil1 0W-40 DexosR that's "approved".
