12-24-2013, 11:55 AM | #1 |
Drives: 2010 Camaro SS Join Date: Jun 2009
22s rear, 20s front anyone?
Have looked at a thousand photos. Anyone ever considered 22s at the rear with 20s at the front? Wondering how a classic muscle car rake would look with CV3s or D2s. I'm guessing coil overs would be required to get the wheel well spacings adjusted just right.
12-24-2013, 12:21 PM | #2 |
Untamed Performance EPT
Drives: 2011 2SS Join Date: Aug 2012
I'm certain that will trip your "Service stabilitrack" message and disable your ABS and traction controls. There's a small % of allowable difference in diameter between front and rear tires. If you go outside that %, it will trip. I'm currently thinking I have that problem even though the diameters are the same. Wheel speed sensors detect the RPM of the wheel
Night Fury Cam
Borla LT Headers and Borla Cat Back ATAK 9in. diff with 4.11's, DSS Axles, and Alum Shaft Hurst Short-Shifter; Ideal Garage Master Cylinder H-E Street Slayer Twin Billet Clutch BMR: Adjustable; Trailing Arms, Toe Rods, Extreme Sway Bar. BMR Subframe Bushings. Strange Rear Coilovers and mounts Tuned by Rhino79 |
